I remember the CZ 250 and 175 well. Farm implements were better appointed.Druid wrote: ↑Wed Dec 30, 2020 7:13 pm
I passed my test on one of those, borrowed from a mate because my Honda CB250 wouldn't start. I progressed to a T500, which also had a kickstart on the left.
I also had a CZ250 which had a gear lever which doubled as a kickstart. You had to push it inwards and then swing the lever upwards, kick it to start and then swing it back to its gear lever position. Try doing that when you've stalled at a set of traffic lights.
My GS750 has a kickstart and an electric start. The kickstart fouls the modified rearsets so I've removed it, by the mid 70s Japanese starter motors were pretty reliable, I think kickstarts were only fitted for those who were stuck in a time warp back then and didn't trust these new fangled electrical contraptions. If you have any experience of the "electrically assisted starting" fitted to Norton Commandos you can understand their scepticism
On my R90S the kickstart was on the left and operated at 90 degrees from a normal kickstart. Best have it on the stand for that trick.
