JAPton blog
Has thanked: 11036 times
Been thanked: 4067 times
Re: JAPton blog
mangocrazy wrote: Fri Jul 24, 2026 9:42 am Well done, that man. Perseverance pays! The exhaust sound with no silencer was enough to wake the dead. What's it like with the silencer?
Cheers!
TBH, err... not a lot different! :D :D
IIRC the story goes that it's off an old BSA M21 (or something similar) and was only chosen by my Dad because it's the correct bore to fit the enormous downpipe! :D
crust wrote: Fri Jul 24, 2026 9:56 am Fantastic!!!
What an excellent reward for all your hard work and perseverance :thumbup:
Thanks!
JackyJoll wrote: Fri Jul 24, 2026 12:52 pm I have never found those nylon bases prone to leak, so it should be fixable, maybe with a replacement gauze.
Any piece of Hylomar that comes off downstream of the gauze will roam around the float bowl like the Flying Dutchman, until it causes trouble.
I mounted a small resin-filled coil too close to an iron cylinder head and the coil cracked.
I do still have the old coil, and I know where to source them if I need a new one. I think it's far enough away, but given that I want to do another slight mod... it may well get moved.
Re the nylon filter - I've been scouring the photos I can find online and none of them seem to have that lip - so I think I've just got two very old, work filters and will buy a couple of new ones at the earliest opportunity (Sunday at Ardingly if I make it, Sunday evening online if not. :) )
Thanks everyone for the replies, tbh there were times I wasn't sure we'd get this far. :D I can't wait to get it on the road... :D (It's currently still registered and insured, and doesn't even need an MOT iirc!)
:banana-wrench:
Re: JAPton blog
Actually, one thing I should admit to... if only for recording the idiocy for future referral....
When I did the ignition timing I didn't check the documentation for the Mag.
The mag shaft actually has a direction indicator on it (in the document it's an arrow scratched onto the end of the shaft, on mine I think it's a punch mark that's distinctly off-centre). The arrow indicates the desired orientation of the shaft when setting the time... it must be pointing "down" when you're setting the timing so that the spark occurs at the right point in the 4-stroke cycle (the mag is driven by the camshaft, which turns at half engine speed)
I completely forgot about that mark, and so didn't check it when I did the ignition timing. :roll: :? :? :?
I had a 50% chance of getting it right.... :D :D :lol: :lol:
:banana-wrench:
Has thanked: 8073 times
Been thanked: 5730 times
Re: JAPton blog
Rockburner wrote: Fri Jul 24, 2026 2:11 pm Actually, one thing I should admit to... if only for recording the idiocy for future referral....
Probably find the engine was running perfectly....backwards. :D
Has thanked: 19695 times
Been thanked: 4979 times
Re: JAPton blog
Mate, I'm sitting here (in the last throes of a migraine) and grinning like a raving loony !!!! How bloody awesome!
I'll be honest that I mostly. just look at the pictures cos I don't really understand most of the words!!!
But seeing that start and the noise . . . . WOWOWOWOWOW Bloody freaking awesome :) :)
:bblonde: :bblonde: :bblonde: :bblonde: :bblonde: :bblonde: :bblonde: :bblonde: :bblonde:
Been thanked: 1232 times
Re: JAPton blog
Yeah that doesn’t look right.
There’s no doubt Amal are capable of selling bad parts.
Re: JAPton blog
So, I couldn't help myself and wandered back over to the workshop this afternoon. :D
My first intent was to sort out that banjo union.
I started by taking it apart and discovered that I'd done it up so tight that the washer under the bolt had disintegrated!
But weirdly, I still don't believe that was leaking!
I started examining all the bits as closely as possible and started to get suspicious about the banjo union itself:
I then dug through all the old odds and sods that I had from Dad's workshop...
And eventually I discovered that I had a nearly new Amal nylon filter!
I think this was part of the upgrade parts I bought for the Monobloc - that's where I found it anyway, in the amongst the Monobloc stuff. It definitely does NOT have that lip.
So, I fitted it, and re-did the petrol pipe on the banjo union as well and ... er... it seems to have fixed it! :D :D
I also found I have a couple of competely useless twin feed banjo unions...
So while I was waiting for fuel to seep through the filter, I had a mooch around the rest of the bike...
And found this:
Buggeration!
So, I started stripping the rear mudguard off the bike:
First off - the catch-tank holder.
That long screw is what holds both the mudguard on, and the catch tank!
Removing the upper bolts
All undone, and it pulls out actually surprisingly easily.
You can see the "cut out" on the side clearly here, and this is the cause of th cracks.
The larger crack is clear :
Sorry - did I jump ahead of myself... yes there's 2 cracks
Lower end
Upper end
Cleaned off the inside and marked the end of the cracks with a white paint pen.
The holes were drilled easily after judicious use of a centre punch
3mm each should be enough. (They look a bit bigger because I cleaned then up a bit with a larger bit.)
The mudguard went back in fairly easily too.
First getting that long set-screw in place
I was sweating having to take the rear wheel out, but I didn't need to: the set-screws at the bottom end are allen-heads, and there's enough clearance to get the long set-screw out of the bracket, luckily.
Once I had the mudguard back into place.. I had a close look at the fitment.... and now I'm wondering why the hell the cut out is there!
I then fitted the tank strap.
First I got the tank out of the way - there's just enough play in the fuel hose to allow this :
More ultra-lightweight fitments...
And I locked-wired the R-clip just to be safe.
The other end of the strap is yet more in the ultra-lightweight theme
Fitted the seat
Fully bolted down
A while ago I decided that I don't like the Unity Equipe screen that comes with the nose-piece, so I made up a lower, darker version.
It needs a bit more work, the top corners need to be curved off and tidied, but that shouldn't take long with a dremel.
I fired it up again in order to try to get the tick over improved (it either hunts and dies, or revs like crazy at the moment)
Didn't realise that strap was actually pushing against the downpipe... oops! :D
Gassed myself, obvs!
The last piece... Dad's home made primary chain cover.
There's nothing left to fit.
I pondered taking it out at that point..... but realised I'd run out of daylight! :lol: :lol: :lol:
I am interested to see how it runs ... I expect there'll be a fair bit of carb tuning to be done.
Hopefully soon! :D
:banana-wrench:
Lutin
Has thanked: 377 times
Been thanked: 388 times
Re: JAPton blog
Post by Lutin »
Splendid. :clap:
Re: JAPton blog
The delights of WFH. :D
Those sharp angles and cracks on that cut-out are text book stress-raiser illustrations. I'd have been tempted to round 'em off with a rat-tail file or summink.
Top work though. :thumbup:
Do you plan to tax/insure it and get out and about on it while the summer lasts? (Is it road legal?).
Re: JAPton blog
Count Steer wrote: Sat Jul 25, 2026 8:18 am The delights of WFH. :D
It's registered (tax is £0), and insured, and is old enough not to need an MOT....
:banana-wrench:
Re: JAPton blog
Today, after a bit of car booting, (found a large Elora spanner that will hopefully be useful, 1"W & 1.1/4"W) and wandering around town, I popped back into the shed to carry on prepping the bike.
First I drained the old oil, it turned out to be C40 from the last time the bike was run.
It's bloody hard to see into the oil tank...
I've got a couple of litres of new Morris C40...
And I also have these....
The Morris is nigh on transparent when it's clean...
One tin of Castrol is obviously used.... Euuuw
Will have to get rid of that some how... Dad would have just chucked it on a bonfire! :D
The other tin was still sealed, and is nice and clean.
It looks like the still plenty of room in the oil tank, so I'm going to get some more C40 and top it up to about 3.5 - 4 litres.
In the meantime time I added a dribble of the R30... ;)Image
After that I messed around for a bit making sure the bike was ready, and prepping a toolkit to carry on the bike, before nipping inside and putting my gear on.
I also remembered to pour some more petrol in the tank! :D
The first ride was, to be honest, both exhilarating and a bit of a let down! :lol:
I did a couple of loops around the triangle of roads near the house, and it runs fine, handles fine (the something odd, tyre pressure, a bearing or something), however it's pretty gutless. I wasn't expecting a rocket ship by any means, but it still felt a touch underwhelming. It pulls ok up to about 60-65 then seems to completely run out of wind.
I was going to carry on a bit further afield, but looked down at the engine and realised that the cases were covered in oil, so, I returned home to check things over.
That's after just a couple of minutes back on the work ramp
This is main feed pipe to the pump, dripping wet
This push rod tube is loose enough to be rattled, and is definitely one of the sources of the external oil.
There was so much oil it was pouring over both sides of the cases, although sitting it on the side stand for a few moments would have caused that.
This is somewhat concerning though, a pool of oil by the rear left head stud, seems an odd place for it to be, unless the base gasket has gone already..
The exhaust "was" nice and shiny...
The plug actually doesn't look too bad if you ask me.
It's not quite right, but I've definitely seen worse!
I left it to cool off before I clean it up, then may look at reducing the amount of oil being pushed to the head, one of the books says it should be " a drip for every 2 pulses of the pump" (you can see the pump pulses through the window on the pump), but that's a rate for racing WFO, so I think I'll reduce the feed to a drip every 3 or 4 pulses, and try to do some mitigating of the leaks!
There's also lots of other little niggles, the gear lever is a bit high, the nose cone isn't straight, the left fork leg seal has gone, etc etc.... nothing insurmountable though. But some things are fine, the rear brake works perfectly, the front is okay etc. So I need to do a few more things before it's fully ready...
That said... It's the local classic club monthly show tomorrow, and that's only about a mile away from the house... :D
:banana-wrench:
Re: JAPton blog
Gutless?
I suppose at this stage you don’t know if the main jet and needle height are right.
Is the ignition timing kind of open to debate? If it’s right, retarding it slightly while the engine is pulling hard won’t have a significant effect.
Retarded inlet valve timing has a bad effect on low-mid rpm pull.
I suppose that silencer is not restrictive.
iansoady
Has thanked: 72 times
Been thanked: 246 times
Re: JAPton blog
Post by iansoady »
To be honest, 60 - 65 at this stage is quite respectable. I'd expect no more than 80 flat out from a JAP 500.
I don't envy you trying to clean out Castrol R if it's been sitting in the engine for a long time.
Re: JAPton blog
True, I’d say the top speed of my 1955 AJS 500 road bike was 80 mph. Newer but less sporty than the JAP I suppose.
Re: JAPton blog
That is so so awesome to see. A thing of beauty even if currently a bit gutless.
That's the sort of bike I stop to watch go by (or will go over if parked and have a really good look at all the bits that mean nothing to me ) :) :) :)
I hope you sort the oil leak and find something that makes it feel less gutless. But even if that stays - it is absolutely gorgeous :wub: :wub: :wub:
Ian
Has thanked: 1376 times
Been thanked: 589 times
Re: JAPton blog
Post by Ian »
Fantastic 👍 I've been away and missed all the excitement :banana-wrench:
Re: JAPton blog
Ian wrote: Sun Jul 26, 2026 2:58 pm Fantastic 👍 I've been away and missed all the excitement :banana-wrench:
I reckon RB owns that -------> :banana-wrench: now. :D
Re: JAPton blog
JackyJoll wrote: Sun Jul 26, 2026 9:51 am Gutless?
Exactly, it's running ok, but in haven't played with anything yet. It tends to tick over very quickly.
JackyJoll wrote: Sun Jul 26, 2026 9:51 am Is the ignition timing kind of open to debate? If it’s right, retarding it slightly while the engine is pulling hard won’t have a significant effect.
I have multiple sources for the ignition setting, most of them disagree... :lol:
But my Mag has automatic advance retard, so messing with the timing is a bit more involved.
:banana-wrench:
Re: JAPton blog
iansoady wrote: Sun Jul 26, 2026 9:58 am To be honest, 60 - 65 at this stage is quite respectable. I'd expect no more than 80 flat out from a JAP 500.
The engine has been completely to pieces... There no R in there yet! :D
:banana-wrench:
Re: JAPton blog
Report from the weekend.
I snuck into the workshop late Saturday evening and did some more checking and tinkering.
I decided to try RTV-ing the rocker cover:
I also realised that the fuel line was very very close to the spark-plug cap, and then remembered that I'd seen a 90 degree fuel union somewhere... so dug it out and this is a lot neater (if needing a bit of a clean up)
I'd decided to forego the Ardningly bike-jumble in favour of actually getting the JAPton out and visiting the local classic meet.
So, Sunday morning I checked the oil:
4.6cm as a baseline.
Oh - and I added the finishing touch..
:D :D :D
Made it to the meet alright (even though I went to the wrong location first..... D'oh!)
Got a fair bit of interest from everyone, mainly because it's 10x louder than everything else, so your arrival is noted.... :D
On the way home I nearly had a KSI, I was coming up for the turning into my driveway, a right hand turn, so I stuck my arm out for at least 5 seconds (I learnt how to make VERY OBVIOUS hand signals a long time ago riding Dad's old bike collection), brought my hand back to make the turn, and the ABSOLUTE TWAT in the Merc CLK tailgating me OVERTOOK ME.
IF he'd been a microsecond less impatient, he would have had me over his bonnet.
I was so enraged I chased him down with the horn blaring and gave him a piece of my mind (the only bit working, sadly). Didn't really resolve anything, but I think I did get an apology out of him... (eventually, after I had to apologise for using bad words at him, wtf?? He was at least 30, has he not lived in the real world? :wtf: ).
Post-mortem of the ride: The RTV on the rocker cover seems to have worked, but oil is still pouring out of the engine somewhere. The most obvious location would be the base of the push rods, and it's got me thinking: I reckon it needs a crankcase breather.
The engine, as designed, has a crankcase that is (essentially) open to atmosphere, so the down-stroke pressure wave has somewhere to go. Now that my engine has the return pump blocking that exit route, and there is no longer a cable-operated decompression lever, there's no crank-case breather. The De-comp system in the timing chest was cable-operated, so there WAS a route to atmosphere through that cable (not great, but there).
I'm going to talk to one or two people about it, but I'm pretty sure I need to put a breather tube into the crankcase/timing chest, luckily, there's a very obvious and handly location for one. :D
I also reduced the amount of oil flowing to the head, siply to reduce losses but if the fitment of the breather works well, I'll wind it up again to make sure the head gets enough (it doesn't want too much otherwise the oil overwhlems the valve-stem requirements and gets into the head). I reduced it down to about 1 drop every 7 -10 seconds (it's difficult to get an accurate measure with the random tickover...)
:banana-wrench:
