'83 GPz750-A1 malarkey.
Has thanked: 2232 times
Been thanked: 2618 times
Re: '83 GPz750-A1 malarkey.
Visited the GPz750... Noticed the right clip on is bent & the plate that goes between the frame tubes above the battery is missing.. & the two holes for the bolts that hold the plate in place have snapped off bolts in them...
Found a NOS OEM clip-on for $10.29. Bargain.
Off to Rosamond to visit APE & spend some $$...
WooT!! Pods & manifolds, $145.
Now, choices..
Option one: Do I put the news pods on the GPz750...
Option two: Put them on the ZRX11 & take the ones on the ZRX11 & put them on the GPz750?
I'm tempted to put the new ones on the ZRX with the spiffy green filter oil I have, so extra green on the ZRX11 making it even faster...
Dismantled three brake calipers (fronts & the rear are the same). Had previously ordered rebuild kits without the pistons.. however, I need the pistons...
Bugger.
Gonna order three new kits WITH the pistons (FFS).. & I guess I now own 3 rebuild kits for the '83 GPz11 which has the same brake calipers etc.
Calipers, mounts & other gubbins had three 30 min sessions in the ultrasonic. Calipers were originally anodized, but that's all faded to shit on the exposed surfaces (which is why the rear caliper is still dark). May paint them, or install as is...undecided.
bluergh... Can't understand why people reuse the same solution in ultrasonics for weeks, all that snarge on the bottom decreases the efficiency of the machine.. but they save maybe 10c on detergent, the cheap fucks.
A_morti
Has thanked: 405 times
Been thanked: 812 times
Post by A_morti »
You're in the desert, right? Anodising loominum parts is essential if they'll ever see salt, but maybe optional where you are.
They'll look nicer if they match each other though.
A_morti wrote: Thu Jul 02, 2026 2:59 pm You're in the desert, right? Anodising loominum parts is essential if they'll ever see salt, but maybe optional where you are.
They use grit, not salt on the roads here when it gets icy or snows. If I go with caliper paint they'll most likely end up silver.
We don't get proper snow very often on the desert floor, altho the local mountains get several feet every year & the freeway to LA sometimes get closed. That kid in the pic is 29 now...
Green pods :)
Cleaned up the caliper brackets & gave then a quick squirt of that Steel-It paint. In related news, that stuff matches the original finish on the GPz750/1100 rear brake levers. I hadn't noticed when I painted the lever off the GPz750, then I was working on the GPz11 last week & realized it's a perfect match.
