'83 GPz750-A1 malarkey.
- Has thanked: 2197 times
- Been thanked: 2558 times
Re: '83 GPz750-A1 malarkey.
Plan for the weekend is fit one set of rails to the GPz11...& maybe assemble the carbs depending on how hard the paint is.
Started carb assembly today, ended up raiding the spare set for the floats, a couple of the caps & some hardware.
Two new key blanks arrived & another fuel tap just so I could use the plastic filter doodad from it.
Tomorrow:
Decided to paint the mounting rails & some other bits with Steel-It instead of the gloss black epoxy. Going to use that stuff on the rear brake lever too.
Tomorrow:
Emptied out the tumbler this morning to see if I missed any parts in there... it's like picking fly shit out of pepper. The media is 8mm stainless steel pins
Threw another load in there for 3 hours.
- Has thanked: 13072 times
- Been thanked: 14134 times
Looking great man.
Carb rails & brake lever got the Steel-It treatment this morning. Lever looking spiffy... other bits just got turned over & painted on the other side, so they still sitting in the Sun
Have to be a bit quick with this paint as it comes out of the rattle can like a frigging fire hose.
- Has thanked: 623 times
- Been thanked: 9351 times
Rear brake pivot doodad also just got the Steel-It treatment, currently hanging on a piece of welding wire outside in the sun.
Finished the tumbling...well, for now. They'll be more hardware from the fairing, front fender, footpeg mounts etc when those parts get pulled off the bike.
There's duplicates in this pile as some parts are from the spare set of carbs. Ferinstance, the thicker idle screw is from the original carbs & the thinner one is from the spare set, as are a lot of the screws.
https://steel-it.com/KungFooBob wrote: Tue Jun 16, 2026 8:46 pm Never heard of Steel-It, but that looks like a nice finish.
It comes out the rattlecan so frigging fast you'd think there's going to be runs, ripples & orange peel etc, but it smooths out perfectly. It's not exactly cheap, a rattle can of this stuff was $41. But that one can has done a some GPz750 parts, the brake plates, rear axle & pumpkin on the F350 & there's still plenty left in the can.
