Suspension Help.
Has thanked: 12412 times
Been thanked: 8418 times
Suspension Help.
When I was racing and instructing I always had free suspension set up so never really learned much.
I sort of know the theory, but not the practice.
The suspension on the GSXR has always been perfect, but recently I can feel every bump on the rear suspension.
So should I make it a bit softer? Harder?
Adjust compression or rebound?
It still handles amazingly well so don't want to bugger it up as I'm at Portimao next week
Ta. :)
crust
Has thanked: 921 times
Been thanked: 685 times
Re: Suspension Help.
Post by crust »
Eat less pies.
Wear an extra pair of skiddies.
HTH
crust wrote: Wed Jun 03, 2026 12:21 pm Eat less pies.
HTH
Fewer darling, fewer 😉
Has thanked: 13063 times
Been thanked: 14128 times
Set the sag on the bike for your weight. Then you can toosh about with damping. Loads of videos on the Tube from the likes of Dave Moss and others. Having a mate to hand is useful,or you can buy a Motool Slacker and do it on your own.
A_morti
Has thanked: 403 times
Been thanked: 806 times
Post by A_morti »
Is it the same as it ever was but you've become more sensitive to bumps, or has it deteriorated over time?
If it's deteriorated over time, then considering the bike's age, track use, and hot ambient temperatures, the damping oil could have gone bad or the pressurising gas may have escaped. If that's the case you could try to mask it by turning any damping screw in just a little, but it won't play well when you ride it extra hard so it might just be time to get it serviced or replaced.
Could also be that the linkages need a service. If the bearings seize, they prevent the shock from absorbing small impacts.
Is this just the universe telling you it's time for a brand new bike? Might be the longest you ever kept a gsxr.
Been thanked: 4523 times
Check the tyre pressures first
A_morti
Post by A_morti »
Yorick wrote: Wed Jun 03, 2026 10:55 am When I was racing and instructing I always had free suspension set up so never really learned much.
Ta. :)
Did it play nicely?
A_morti wrote: Fri Jun 12, 2026 7:00 pm
Ta. :)
Did it play nicely?
Aha. Gotcha.
Yes, it's fine on track. Just road bumps upset it a bit.
The suspension guy had a fiddle both ends but it didn't change much on track today.
But might help on road. I'll report back when I'm home
Has thanked: 19158 times
Been thanked: 4884 times
Ask the suspension guy at track about the road stuff. If yr seeing him to get stuff checked for track, worth an ask for when you get home.
Might not be anything you can do, and if you’ve lost weight in yr butt, maybe you’ve just lost some natural padding (wanted to use a suspension word but have zero idea if it’s damping or rebound 😇😇)
The guy is there for track but pretty sure he’ll be able to help for road too 👍🏻👍🏻
Noggin wrote: Sat Jun 13, 2026 8:47 am Ask the suspension guy at track about the road stuff. If yr seeing him to get stuff checked for track, worth an ask for when you get home.
Every time I've had a bike set up for track, it's been perfect on road.
Not too much difference.
Yorick wrote: Sat Jun 13, 2026 9:17 am
I found that, but I am, was, a lot slower than you, so didn't want to assume :lol: :lol: :lol:
