'83 GPz750-A1 malarkey.
- Has thanked: 2193 times
- Been thanked: 2558 times
Re: '83 GPz750-A1 malarkey.
Yay! I now have a kickstand spring.. that came with kickstand #3.. FFS
#1: Came with the bike
#2: Ordered on April 30th, arrived three weeks later without the bloody spring... Was dropped off for powdercoat today.
#3: Arrived today, with the spring
It's now in the tumbler.
Removed two of the choke plungers from the spare carbs. Took a look in one of the float bowls... which was unsurprisingly cleaner than the carbs I removed from the bike...
Weekend off from the project, but did score a pair of 750 Turbo side covers for a mere pittance
In other news:
That spring was sitting in the citric acid but there wasn't much of a reaction going on, then I put the jar it was in, in the small ultrasonic & it really started cooking off.
Decided against bare carbs, so carb bodies masked off. Need to fit float bowls & get spraying with shiny black epoxy paint.
Threw some paint on the carbs & the two rails they all mount to....did it outside in 101deg sunshine
Powder coated doodads will be ready for pick up at 3pm Friday.
I've barely scraped the surface... All I've done so far is strip, clean & make the carbs look spiffy, plus drop off stuff for powdercoat & buff the sidecovers & tail somewhat...
& fuck about with the gastank a bit.
& fit the new ignition doodad.
Unmasked... just need to remove what's left of the cotton wool I stuffed in various holes...
- Has thanked: 20543 times
- Been thanked: 13440 times
In all my years around bikes, I can't recall ever coming across a bike with non alloy finish (unpainted) carbs before?
eh? you've not seen bare metal carbs before?Taipan wrote: Fri Jun 12, 2026 10:01 am In all my years around bikes, I can't recall ever coming across a bike with non alloy finish (unpainted) carbs before?
- Has thanked: 13072 times
- Been thanked: 14134 times
Common on the GPZ range of bikes.
I could have bought a decent runner that needed nothing, but I'd rather bring this one back. Altho with that said, if this '81 GPz11 had shown up first on FBMP I'd have bought it instead... which I may still buy as wellA_morti wrote: Thu Jun 11, 2026 10:42 pm From the first posts I thought this one was past (worth) saving, but you're certainly turning it around and quick
Powder coat doodads looking spiffy
I ended up with an extra grab rail that came with the tail & other set of rails I bought, so that went in the pile for p/c.
- IMG_20260612_172029362.jpg (2.2 MiB) Viewed 53 times
