Amoi being unreasonable
Has thanked: 24 times
Been thanked: 355 times
Post by ..... »
Swmbo had tyres replaced and neededanewtpms according to the dasteadoutmsstillneeds anewtpmswhich the tyre shop wants to charge €60tofit€10for thebit
Expressed thopinionto the salessmanagerthat€60os excessive for something that should have been done when the tyres were fitted
Re: Amoi being unreasonable
The batteries in the sensors should last 5-10 years. How old are they?
Has thanked: 8034 times
Been thanked: 5692 times
Strange that it happened when the tyres were replaced. :hmmm:
Could it be that the valve bits need re-linking to the system? I'm sure there's something in the manual of my wife's car about doing that.
Also a bit :hmmm: that the tyre people didn't mention anything. I thought they check these things. Maybe @Jody will have an idea. IIRC he did the occasional stint as a tyre fitter.
Has thanked: 3644 times
Been thanked: 2502 times
Our Tuscon needs a good drive for the tyre pressure sensors to sort themselves out/get recognised by the car after a tyre is swapped or I put the spare on.
Has thanked: 2317 times
Been thanked: 1821 times
Post by Jody »
..... wrote: Sun Apr 12, 2026 6:24 pm Swmbo had tyres replaced and neededanewtpms according to the dasteadoutmsstillneeds anewtpmswhich the tyre shop wants to charge €60tofit€10for thebit
€10 for the part is cheap imo, €60 to fit is horrrendous. are you sure you have it the right way around ?
Question is, why did it need replacing?. If the dashboard light wasn't on when she drove in, then that indicates the sensor was working properly. It IS entirely possible for a careless tyrefitter to break a TPMS when breaking the bead of the old tyre. It's stupid mistake, but I can't say I haven't done it.
