Preventing Punctures.
All things dirty!! From tyres, to helmets, from GPS to map reading.
Has thanked: 12604 times
Been thanked: 8535 times
Getting fed up of punctures. Tried the Tubliss system my pal runs but got more punctures than normal.
So now gone for 4mm inner tube on front.
I carry that spray can puncture repair, but often it's too late as the valve stem has been ripped off the tube.
Is there summat that I can put in before I ride?
I like to run both tyres about 10 psi.
Any advice?
Been thanked: 2727 times
Re: Preventing Punctures.
Mousses rather than inner tubes?
cheb wrote: Mon Feb 16, 2026 5:16 pm Mousses rather than inner tubes?
It's hard to regulate the tyre pressures. I can't stand up on the bike so ride sat down.
I can feel big differences with wrong tyre pressures.
Has thanked: 20853 times
Been thanked: 13667 times
I put slime in my tubes to try and reduce the gradual pressure loss. I then got a puncture and even though it shouldn't work, it did. It was only when i got home i noticed all the luminous green stuff over the inner mudguard and swinging arm and realised i had a puncture.
Have you got rim locks, it sounds like tyre movement is ripping the valve from the tube rather than you getting punctures,
Le_Fromage_Grande wrote: Thu Feb 19, 2026 8:20 pm Have you got rim locks, it sounds like tyre movement is ripping the valve from the tube rather than you getting punctures,
Yup, they come as standard.
Yorick wrote: Thu Feb 19, 2026 8:21 pm
Not that then
Le_Fromage_Grande wrote: Thu Feb 19, 2026 8:23 pm
Not that then
Probably 10 mm big blobs of rubber, no sharp objects.
Infuriating
Move back to England. No nasty, sharp volcanic rock here, just mile after mile of lovely soft, muddy, rain-filled ruts and trenches! :thumbup: :wtf:
Taipan wrote: Sat Feb 21, 2026 5:28 pm Move back to England. No nasty, sharp volcanic rock here, just mile after mile of lovely soft, muddy, rain-filled ruts and trenches! :thumbup: :wtf:
I really miss rain and mud :(
