Exactweld TZ250
Been thanked: 2618 times
Exactweld TZ250
Nobby
Has thanked: 85 times
Been thanked: 477 times
Re: Exactweld TZ250
Post by Nobby »
My BiL rides their Bike in the European classic open class. It is a thing of engineering beauty. Ill hunt out some photos.
Nobby
Re: Exactweld TZ250
Post by Nobby »
Look at it carefully , the more you look the more you’ll find.
This was the Bike a few years back. It has a new front end now.
Nobby
Re: Exactweld TZ250
Post by Nobby »
Whysub
Has thanked: 1055 times
Been thanked: 861 times
Re: Exactweld TZ250
Post by Whysub »
I remember one being raced in various 250cc club championships in 1994/1995. It was a scruffy, run of the mill looking bike, but it transformed into something really interesting once the bodywork was off.
Re: Exactweld TZ250
Nobby wrote: Thu Dec 24, 2020 4:43 pm 7A0C6AF4-ECA2-44CA-B85E-7982D3367AB4.jpeg
That is very pretty.
Nobby
Re: Exactweld TZ250
Post by Nobby »
cheb wrote: Thu Dec 24, 2020 6:45 pm
It's their own engine. A twin tandem disc with 4 carbs. Rear end bolts to the crankcase and front on the cylinder head.
Have you spotted the rear brake system ?
Re: Exactweld TZ250
Using a pipe as the stay rod to save weight?
Nobby
Re: Exactweld TZ250
Post by Nobby »
cheb wrote: Thu Dec 24, 2020 8:01 pm Using a pipe as the stay rod to save weight?
yes , and the master cylinder as the lever as well.
Re: Exactweld TZ250
Yes, now I squint at it a bit harder.
Has thanked: 1350 times
Been thanked: 1726 times
Re: Exactweld TZ250
Cathcart always did write the best stuff for PB years ago and that article being one of his just confirms it.
Has thanked: 2636 times
Been thanked: 1523 times
Re: Exactweld TZ250
I remember seeing that out on the circuits...
Nobby
Re: Exactweld TZ250
Post by Nobby »
inewham wrote: Fri Dec 25, 2020 1:32 pm I had always thought it was a rotax engine, I didn't realize it was their own engine too :thumbup:
Another dodgy photo taken from the Internet
Nobby
Re: Exactweld TZ250
Post by Nobby »
inewham wrote: Sat Dec 26, 2020 1:42 pm Can someone tell me the advantages of a tandem twin over a more conventional parallel twin?
You can use disc valves on a parallel twin and surely there must be losses gearing the 2 cranks together.
They seemed popular for a while in the 80s but ultimately V-Twins seemed to work better
Me, thinking on the top of my head and don't know shite.....would assume that a single/ parallel transfers are not restricted by the confines of having to squeeze cylinders together. Is a guess. I shall get that question off to the Boys that designed it.
porter_jamie
Has thanked: 255 times
Been thanked: 143 times
Re: Exactweld TZ250
Post by porter_jamie »
Package, and you can have a disk valve on both sides
Re: Exactweld TZ250
It'd be narrower, and with with small capacity water cooled cylinders there'd be no extra cooling problem nor would the motor be too long.
The crankshafts would turn in opposite directions too, that might be an advantage.
That's my guesses anyway.
