Decision, which Whyte?
- Has thanked: 6125 times
- Been thanked: 15488 times
Re: Decision, which Whyte?
lol I don’t need selling on Bosch as a plan.
I’m just needing house move done and I then expect to see a Sly
Taff
- Has thanked: 334 times
- Been thanked: 1191 times
Mate, I see that it sounds daft but I'm not a novice mechanic, I fixed sea harriers and lynx helicopters for 22 years and It's not my first motor removal, dropping the motor out of the Cannondale was a doddle because it literally dropped out of the frame, but the Whyte is an absolute cnut of a bike to get the motor out of because the frame wraps tightly around the motor and there's bugger all clearance for the cables going up and around it.
The motor just gets jammed until you get it into the perfectly right angle and then it slips out.
The orbea was a bit like that too, you’re fighting it for ages then suddenly it falls out and lands on the floor lolTaff wrote: Tue Jan 06, 2026 8:17 pm Mate, I see that it sounds daft but I'm not a novice mechanic, I fixed sea harriers and lynx helicopters for 22 years and It's not my first motor removal, dropping the motor out of the Cannondale was a doddle because it literally dropped out of the frame, but the Whyte is an absolute cnut of a bike to get the motor out of because the frame wraps tightly around the motor and there's bugger all clearance for the cables going up and around it.
mboy
- Has thanked: 854 times
- Been thanked: 696 times
I get it don't worry... I was incredibly careful the first couple of motors I dropped, and then getting them back in would swear they didn't actually go back in for the exact reasons you state...Taff wrote: Tue Jan 06, 2026 8:17 pm Mate, I see that it sounds daft but I'm not a novice mechanic, I fixed sea harriers and lynx helicopters for 22 years and It's not my first motor removal, dropping the motor out of the Cannondale was a doddle because it literally dropped out of the frame, but the Whyte is an absolute cnut of a bike to get the motor out of because the frame wraps tightly around the motor and there's bugger all clearance for the cables going up and around it.
Simple fact is, on some bikes you've just gotta jam it back in there! It's not nice, it feels dirty doing it, just don't pinch anything and you're good.
I will say that the older 6 bolt mounts that Bosch/Shimano used were a massive PITA... The newer 2 bolt mounts used by Bosch on the Gen5 CX and SX motors is way easier as once you've got the cables where you want them and are holding the motor in position, you can just slide a long bolt all the way through one of the holes and without even screwing it in, the motor is now held in place... A nice little touch from Bosch to make mechanics' lives easier on the newer motor systems that most riders will never realise.
- MingtheMerciless
- Has thanked: 3644 times
- Been thanked: 2502 times
The EP8 in the Evil is a faff too, it’s very easy to damage the wiring loom refitting the motor.
