It's not a new idea, and it has been proposed, and I believe some are already going down this road.Le_Fromage_Grande wrote: ↑Fri Dec 18, 2020 11:01 am If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
The only real issue with it as an idea is that battery tech is changing so fast, as soon as you brought out that kind of infrastructure to the public, it'd be 2 generations out of date. Petrol hasn't changed (fundamentally) in nearly 100 years.
