PSA : Cheap Ducati Arai
- Has thanked: 6125 times
- Been thanked: 15509 times
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
Re: PSA : Cheap Ducati Arai
Must not buy, must not buy, must not buy ....weeksy wrote: Fri Dec 11, 2020 12:30 pm https://www.mandp.co.uk/products/ducati ... ai-dcm0009
£179 instead of £429
- Has thanked: 12617 times
- Been thanked: 8541 times
- Tricky
- Has thanked: 3045 times
- Been thanked: 3309 times
Those colours would match my 765- luckily they don't have one in my size
- Mr Moofo
Buy it then flog it on eBay and make twenty quid
https://www.ebay.co.uk/itm/Arai-Chaser- ... 890.l49292
- Been thanked: 14171 times
Needz Kawasaki instead of Ducati.
- Has thanked: 602 times
- Been thanked: 4529 times
It's a bargain, available in large (like my head) but would I look weird riding a Yamaha in it, and what's the sun visor thing?
IT's a sun visorJulian_Boolean wrote: Fri Dec 11, 2020 4:32 pm It's a bargain, available in large (like my head) but would I look weird riding a Yamaha in it, and what's the sun visor thing?
HTHs
I'm seriously tempted to get it as a spare for trackdays, I've got the same helmet in a normal paint scheme.
Just need to check the one I've got is a large, then it'll get bought, though I'm sure no one here is going to believe my head might be a medium
Beancounter
- Has thanked: 3130 times
- Been thanked: 684 times
It looks gash but works quite well. the only practical downside that I've found is in really hot weather town/city riding - I like to keep my visor up as much as possible so that I get some air flow but you then can't use the sun shade. On the flip side, in Winter, no risk of the sun shade misting up which is what happens with my internal sun visor on my Shoei GT Air.
Is it removable, if you take it off does it leave holes in the visor?Beancounter wrote: Fri Dec 11, 2020 4:42 pmIt looks gash but works quite well. the only practical downside that I've found is in really hot weather town/city riding - I like to keep my visor up as much as possible so that I get some air flow but you then can't use the sun shade. On the flip side, in Winter, no risk of the sun shade misting up which is what happens with my internal sun visor on my Shoei GT Air.
- Has thanked: 359 times
- Been thanked: 919 times
No holes, it just unclips from the main visor. You have to be careful to push the sunshield back in firmly when you're not using it, otherwise it can flip down when you do a shoulder check - not ideal if you're cracking on and it's dark. And it's not easy to pull it forward to lower it when you're wearing thicker gloves - hard to get your fingertips between it and the visor.
Thanks, looks like I'll be making a purchase when I get home tonight, I'm sure I can find something to stick over the Ducati logos, or maybe I should buy a Hypermotard to go with it.
- Has thanked: 19611 times
- Been thanked: 4959 times
I got all excited then remembered that Arai doesn't fit my head anymore
Too many bumps?Noggin wrote: Fri Dec 11, 2020 5:15 pm I got all excited then remembered that Arai doesn't fit my head anymore![]()
Jesus...have the prices gone up?weeksy wrote: Fri Dec 11, 2020 5:45 pmWith the £250 you've saved you can afford to sign up as a member now![]()
