Need to be concerned?
Has thanked: 3650 times
Been thanked: 2505 times
Re: Need to be concerned?
Don’t force it, use a larger hammer!
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
Docca wrote: Fri May 30, 2025 8:31 pm For fucks sake you shits- any sensible suggestions before I go to Reddit? 🤣
Panigale?
Has thanked: 1059 times
Been thanked: 1646 times
Bit of a gues as I don't have bar end mounted mirrors so I'm guessing its mounted like a normal bar end weight.
Is there an Allen bolt in the end of the weight? Loosen that a slightly, push the weight back in and tighten it up again.
The ones Ive seen had an expanding section of either rubber that expanded when it was shortened by the tightening of the bolt or a split metal collet shaped section that a tapered plug pulled into and expanded it.
I've no idea how it would just slide out without the mirror also moving round from the wind when it was loose though.
Has thanked: 2559 times
Been thanked: 4169 times
Conventional (i.e. non bar-end) mirrors are also available.
Has thanked: 2863 times
Been thanked: 3518 times
Is the gap the bar end expanding bolt thing or the handle bar. ?
Has thanked: 8048 times
Been thanked: 5699 times
I thought Mr Longbeard had solved this? :eh:
Docca
Has thanked: 731 times
Been thanked: 1439 times
Post by Docca »
So I’ve managed to tap the ring thing closer to the grip
When putting the indicator back in- I can’t tighten, it just spins and spins. Indicator still works
derek badger
Has thanked: 1091 times
Been thanked: 1762 times
Post by derek badger »
Angle grinder. Job done.
Docca
Post by Docca »
Any genuine suggestions welcome. I’m stuck
MyLittleStudPony
Has thanked: 835 times
Been thanked: 587 times
Post by MyLittleStudPony »
There may be a rubber insert in the bar with a threaded metal centre. The bolt connected to the bar end may cause this to pinch and thus grip the inside of the bar.
The bolt probably holds the bar end in place, which then holds the mirror in place.
This is a guess based on limited visibility!
MyLittleStudPony wrote: Sun Jun 01, 2025 12:23 pm There may be a rubber insert in the bar with a threaded metal centre. The bolt connected to the bar end may cause this to pinch and thus grip the inside of the bar.
Sounds about right - you need it to be done up a bit so that the rubber grips the inside of the bar sufficiently well to allow you to tigthen it. It's the gripping which is allowing you to turn.
Can you pull the indicator out of the bar? Can't really see how it all goes together....
derek badger
Mr. Dazzle wrote: Sun Jun 01, 2025 12:39 pm
Docca can't pull anything out, have you seen how many kids he's got?!
Time for the Gas Axe.
Been thanked: 9505 times
For £500 plus expenses...
Has thanked: 780 times
Been thanked: 3225 times
Docca wrote: Sat May 31, 2025 10:21 am So I’ve managed to tap the ring thing closer to the grip
There's your problem, you should have, and need to get the thing out and find out why it's gone wrong before jamming it back down the bar.
I'm going to guess it's a smidge tight so getting it out now might be tricky, but somewhere inside your bar the nut or expanding section that the indicator screw into have had a paddy.
Docca
Post by Docca »
More pics. I can’t pull the indicator out because the wires are attached internally and the screw is too long.
https://manuals.motogadget.com/docs/mo. ... ctions.pdf
You're missing the washer, rubber part and m8 nut.
KungFooBob wrote: Sun Jun 01, 2025 6:18 pm You're missing the washer, rubber part and m8 nut.
Might still be inside the handlebar.
Has thanked: 19618 times
Been thanked: 4960 times
Someone must be close enough to go offer a hand ???
ChrisW wrote: Sun Jun 01, 2025 6:26 pm
They will be they've no way of escaping, they should be on the other side of the collar he tapped back into the bar.
Best guess is the nut has gone walk about if he can't get it to engage the threaded bar on the indicator.
