How does weather cause snow?
Has thanked: 19576 times
Been thanked: 4950 times
Ok Ok, I know, that's sounds stupid - long day and can't work out how else to phrase it!! LOL
Anyway - down in Aime (about 500m altitude maybe) it was 1 degree and raining this evening.
Got to about 1500m and it was still 1 degree and very wet sleet
1800m - still 1 degree and wet snow
2000m - still 1 degree and dry light snow
How does that work??
I should probably know, but I don't!!
Might be because I'm tired, but I can't get my head around the same temps but the water is less solid lower day!! I've known it snow up here at 2000m when it's warmer than 1 degree. And very very much colder. It's also rained up here at zero degrees
So what gives?
Has thanked: 714 times
Been thanked: 2040 times
Re: How does weather cause snow?
And how does mother nature roll all them flakes flat???
Been thanked: 1228 times
You were at 1500 m, but the snow fell from higher up, where it was colder.
wheelnut
Has thanked: 929 times
Been thanked: 918 times
Post by wheelnut »
Could be wrong but snow isn’t rain that has frozen. The snow forms in the cloud itself (as the water vapour in the cloud starts to feeeze).
Felix wrote: Sat Jan 04, 2025 7:37 pm And how does mother nature roll all them flakes flat???
She's got loads of very fancy "cutters", like for pastry, but more fancy :D HTH :D :D
JackyJoll wrote: Sat Jan 04, 2025 7:41 pm You were at 1500 m, but the snow fell from higher up, where it was colder.
But the temperature was the same at 1500m as it was at 2000m :o
wheelnut wrote: Sat Jan 04, 2025 7:50 pm Could be wrong but snow isn’t rain that has frozen. The snow forms in the cloud itself (as the water vapour in the cloud starts to feeeze).
I didn't know that!!
But it's still weird that at the same temperature but different altitudes the consistency of the "snow" changes - well, weird to me :angelic-green: :angelic-green:
If its turning into rain at lower levels would that not be due to the flake defrosting as its been fluttering down longer than the ones landing up the big hill. <<< cant spell mountain :lol:
Has thanked: 3004 times
Been thanked: 2522 times
Remember your O level Physics.
Frozen water (snow flakes) need a temperature above 0 degrees to start thawing. They also need TIME, they have to absorb (IIRC) 80 calories per gram to turn to water at the same temperature. So at high altitude they can still be snow, a bit lower down when they have had more time they can be sleet, and lower down still they can be rain. All at the same air teperature (above freezing), and still without actually increasing the temperature of the actual snow/sleet/rain.
Doesn't answer the Q directly, but fascinating video if you're fascinated by this sort of thing.
Has thanked: 2290 times
Been thanked: 2675 times
Sometimes when it rains here, it evaporates before it reaches the ground so it stays dry :)
How do you know it is raining?
Cousin Jack wrote: Mon Mar 17, 2025 10:23 pm How do you know it is raining?
She looked down the hill?
We can see it falling higher up in the air. It's called Virga
Timmy
Has thanked: 15 times
Been thanked: 51 times
Post by Timmy »
Noggin wrote: Mon Mar 17, 2025 2:51 pm But the temperature was the same at 1500m as it was at 2000m :o
But it fell from the sky which is higher than the piece of land at 2000m above sea level.
Has thanked: 12607 times
Been thanked: 8538 times
What's snow ?
Has thanked: 20861 times
Been thanked: 13680 times
'It was one of those March days when the sun shines hot and the wind blows cold: when it is summer in the light, and winter in the shade.'
Cousin Jack wrote: Mon Mar 17, 2025 5:11 pm Remember your O level Physics.
Nope, not at all! It was one of the few I passed, but have no memory of learning anything about snow!!!
Saw this online today. The massive snow storm that caused so much damage (mostly to trees) last week was a massive surprise in that the snow fell way further down the mountain than expecdted.
This helps explain that bit - especially as this time it was definitely warmer lower down!! A bit as CJ says, I think, but with added comment about wind helping the defrosting!!
