- gremlin
- Has thanked: 824 times
- Been thanked: 4913 times
The Polar Express.
- Has thanked: 508 times
- Been thanked: 1482 times
Specsavers. Went 7 years ago and got glasses for the first time. Got home and they were shit. Fine reading the card they give you to read but two foot or more (Laptop distance) was a blurry mess. Had to take them back and get tested again and another set of glasses. 2.5 years later, no change in the prescription. 2.5 years later (Last week) apparently my prescription has now changed after being tested. Today got my glasses and read a few things and they seem fine. Got home and cat see my laptop. I have better over the counter glasses.
- Has thanked: 2598 times
- Been thanked: 6375 times
Or you have a problem simple glasses can't fix.
It's how I discovered I have keratoconus for example.
- Has thanked: 6378 times
- Been thanked: 5204 times
Did you specifically tell them you didn't want reading glasses, but for computer use?
https://theeyeplace.com.au/computerglasses/
- Has thanked: 6500 times
- Been thanked: 4879 times
I told my optician I wanted specs for screen work (you can ask for craft glasses too). They asked what distance I worked from the screen and worked on that basis. (Reading is usually closer than screen work and easier to move into focus).Felix wrote: ↑Fri Dec 13, 2024 6:45 pm Specsavers. Went 7 years ago and got glasses for the first time. Got home and they were shit. Fine reading the card they give you to read but two foot or more (Laptop distance) was a blurry mess. Had to take them back and get tested again and another set of glasses. 2.5 years later, no change in the prescription. 2.5 years later (Last week) apparently my prescription has now changed after being tested. Today got my glasses and read a few things and they seem fine. Got home and cat see my laptop. I have better over the counter glasses.
Specsavers are a bit variable though.
I did tell her i do more computer reading than on paper so yes i suppose.Horse wrote: ↑Fri Dec 13, 2024 7:11 pmDid you specifically tell them you didn't want reading glasses, but for computer use?
Now i think about it she did measure the distance from eye to where i would be reading a book/paper then again from eye to laptop distance.Count Steer wrote: ↑Fri Dec 13, 2024 7:12 pmI told my optician I wanted specs for screen work (you can ask for craft glasses too). They asked what distance I worked from the screen and worked on that basis. (Reading is usually closer than screen work and easier to move into focus).Felix wrote: ↑Fri Dec 13, 2024 6:45 pm Specsavers. Went 7 years ago and got glasses for the first time. Got home and they were shit. Fine reading the card they give you to read but two foot or more (Laptop distance) was a blurry mess. Had to take them back and get tested again and another set of glasses. 2.5 years later, no change in the prescription. 2.5 years later (Last week) apparently my prescription has now changed after being tested. Today got my glasses and read a few things and they seem fine. Got home and cat see my laptop. I have better over the counter glasses.
Anyway they are going back tomorrow and probably another eye test.
If you said 'computer' specifically, they didn't didn't get what you'd asked for.Felix wrote: ↑Fri Dec 13, 2024 8:00 pmI did tell her i do more computer reading than on paper so yes i suppose.Horse wrote: ↑Fri Dec 13, 2024 7:11 pmDid you specifically tell them you didn't want reading glasses, but for computer use?
But ...
Did you query it when they gave you the reading test card? You already knew that reading and computer need different prescriptions.
- Has thanked: 16352 times
- Been thanked: 10480 times
Put too much pearl barley in my stew. Proper gloopy! Still lovely though!
They gave me a card today to read and it was fine. They never gave me a loptop to try though. They are going back.Horse wrote: ↑Fri Dec 13, 2024 8:51 pmIf you said 'computer' specifically, they didn't didn't get what you'd asked for.Felix wrote: ↑Fri Dec 13, 2024 8:00 pmI did tell her i do more computer reading than on paper so yes i suppose.Horse wrote: ↑Fri Dec 13, 2024 7:11 pm
But ...
I have bi focals for distance and reading and a seperate pair for computer use. Specsavers told me computer use was different to readers, as the screren is generally that bit further away. I thought readers woud do it but the dont, unless i get closer obvs...Felix wrote: ↑Fri Dec 13, 2024 9:15 pmThey gave me a card today to read and it was fine. They never gave me a loptop to try though. They are going back.
I need to be like Mr Magoo with my head in the laptop screen Got my old readers on now and this is fine as is my over the counter ones.Taipan wrote: ↑Fri Dec 13, 2024 9:20 pmI have bi focals for distance and reading and a seperate pair for computer use. Specsavers told me computer use was different to readers, as the screren is generally that bit further away. I thought readers woud do it but the dont, unless i get closer obvs...
At a guess, they won't have one as a standard check. I've never been shown one. It's up to you to tell them what you need.
Go into Wilco or another cheapo shop. Try some on, stand at screen distance from the test card.
- Has thanked: 16496 times
- Been thanked: 4043 times
You do need to be really specific with Specsavers. Mind you, when they were doing the test to work out my reading distance I was told I wasn’t reading at the ‘correct’ distance - my arms aren’t long enough to hold a book up for any length of time at the ‘correct’ distance . When I pointed that out, she still told me I wasn’t reading at wrong FFS!!!Felix wrote: ↑Fri Dec 13, 2024 6:45 pm Specsavers. Went 7 years ago and got glasses for the first time. Got home and they were shit. Fine reading the card they give you to read but two foot or more (Laptop distance) was a blurry mess. Had to take them back and get tested again and another set of glasses. 2.5 years later, no change in the prescription. 2.5 years later (Last week) apparently my prescription has now changed after being tested. Today got my glasses and read a few things and they seem fine. Got home and cat see my laptop. I have better over the counter glasses.
I got two pairs to ill speak to them tomorrow about one being for computer Probably both as i dont read a great deal and always have an over the counter pair in the car, van, camperbus, Work jacket pocket also.
My wife got a pair of readers also (What were fine) Bloody hell you cant leave these out in the sun. Looks like the jam jar bottoms might start a fireNoggin wrote: ↑Fri Dec 13, 2024 9:50 pmYou do need to be really specific with Specsavers. Mind you, when they were doing the test to work out my reading distance I was told I wasn’t reading at the ‘correct’ distance - my arms aren’t long enough to hold a book up for any length of time at the ‘correct’ distance . When I pointed that out, she still told me I wasn’t reading at wrong FFS!!!Felix wrote: ↑Fri Dec 13, 2024 6:45 pm Specsavers. Went 7 years ago and got glasses for the first time. Got home and they were shit. Fine reading the card they give you to read but two foot or more (Laptop distance) was a blurry mess. Had to take them back and get tested again and another set of glasses. 2.5 years later, no change in the prescription. 2.5 years later (Last week) apparently my prescription has now changed after being tested. Today got my glasses and read a few things and they seem fine. Got home and cat see my laptop. I have better over the counter glasses.
If you're going back, measure the distance that you normally use the laptop at (eye to screen) before you go or take the laptop with you!
Ready readers are all designed for a focal point at roughly the same distance which usually means you have to lean in to a computer screen if you try working in readers. Doesn't bother some but it's probably bad for your posture. People used to worry about screen radiation too but dunno if that all went away with LED screens.
(I made a mistake with my computer/craft specs and scrimped on the frames and they're too heavy so I'm constantly pushing 'em back up my schnoz I really should go and get the lenses put in better frames but I use the laptop less and less and a tablet more and more - and that's held at book distance).
Well old school CRTs are literally particle accelerators, albeit pretty dinky ones. So yeah they genuinely do make radiation if only very small amounts. Flat screens work on a different principle, so no radiation involved.Count Steer wrote: ↑Sat Dec 14, 2024 7:47 am People used to worry about screen radiation too but dunno if that all went away with LED screens.
Re: Glasses though....go to a decent independent opticians is my advice! Specsavers are franchises so they can be hit and miss, some of them are actually pretty good (basically the ones which used to be little independents) whereas some are just sausage factories.
I switched to a local independent a few years ago for esoteric reasons related to the keratoconus I mentioned above. Waaay better though IME.
Karcher arived in a very battered box thanks to DHL monkeys and upon opening it the top half of teh wand is missing!
Specsavers. They made up the wrong prescription. They gave me Readers where computer use ones were ordered. Lucky i never put my old pair in the recycle tub.
