There's 3 other Android devices on the network all are OK so I can rule out a network issue. I left the tablet switched off for a while, when turned on it had my Spanish location but went back to Missouri within a couple of minutes. I can set the time manually but the location thing is a real pisser, any internet searches give results from the US. I've run out of ideas on how to fix it, anyone else got any suggestions?
My tablet thinks it's in the USA
- Pirahna
- Has thanked: 1859 times
- Been thanked: 1197 times
- Has thanked: 543 times
- Been thanked: 7697 times
Re: My tablet thinks it's in the USA
You've been hacked by Russia.
Burn it with fire.
If you're not up for that yourself, for only £500 plus expenses I could help.
Burn it with fire.
- Pirahna
- Has thanked: 2466 times
- Been thanked: 3769 times
318 Shawnee Court, Clever, Missouri
Obvs...
Seriously though, folks. I assume you're running Windows 10 or 11? Perhaps try switching your GPS location off?
To turn on or off GPS location in Windows 11, you can do the following:
Go to Start
Select Settings
Select Privacy
Select Location
Toggle the Location services switch to turn it on or off
Go to Start
Select Settings
Select Privacy
Select Location
- Pirahna
In which case, I have no idea. But I suspect it has somehow fixed its GPS coordinates to Hicksville USA, and you will need to find where in the settings this can be altered. I'd guess that its 'home' GPS coordinates are fixed (wrongly) and need to be toggled so that your actual GPS coordinates are picked up.
- Screwdriver
- Has thanked: 268 times
- Been thanked: 772 times
Not using a VPN are you?
Plato
Plato
- Pirahna
No VPN. I've spent two days searching for a fix and been through every conceivable setting on the thing without success. There's is very little stored on it, I think I'll factory reset it.
- Screwdriver
Don't be so quick to dismiss network/router issue. You may have a different connection using the tablet than the other devices on the same network.
Plato
Plato
Factory reset would be a good starting point. I can't see how it could realistically be a network/routing issue given that your ISP will be in Spain, but if the problem persists after a factory reset, then nothing is off the table.
- Pirahna
My ISP is Starlink, there's not much you can do with the router. My internet facing IP address is a regional Spanish one, nothing funny there either. The tablet is a Samsung, wifey has an older one with no problems, there's also two Android phones with no issues.Screwdriver wrote: ↑Tue Dec 03, 2024 10:51 pm Don't be so quick to dismiss network/router issue. You may have a different connection using the tablet than the other devices on the same network.
- Screwdriver
Sounds like your device is being given GPS data based on the location of the nearest ground based network address. For Starlink that could be anywhere! Way beyond my limited knowledge outside the Apple sandbox (Apple uses "location services" which can be user set for each application ie use WiFi or GPS or Apple database). Does the device even have GPS built in?Pirahna wrote: ↑Tue Dec 03, 2024 11:06 pmMy ISP is Starlink, there's not much you can do with the router. My internet facing IP address is a regional Spanish one, nothing funny there either. The tablet is a Samsung, wifey has an older one with no problems, there's also two Android phones with no issues.Screwdriver wrote: ↑Tue Dec 03, 2024 10:51 pm Don't be so quick to dismiss network/router issue. You may have a different connection using the tablet than the other devices on the same network.
Anyhow agree with above. Hard reset....
Plato
Plato
- Pirahna
There's probably a bloke in Clever, Missouri who's wondering why every app on his device is talking Spanish...
- Pirahna
The tablet has just returned from a trip to Missouri, seems OK again now though.
- Pirahna
Oh, you, pretty Chitty Bang Bang
Chitty Chitty Bang Bang, we love you
