My tablet thinks it's in the USA
Has thanked: 1859 times
Been thanked: 1197 times
    more precisely 318 Shawnee Court, Clever, Missouri. That's the location I get on Google Maps and another couple of map apps I have. The time on the tablet is 7 hours behind as well.
    There's 3 other Android devices on the network all are OK so I can rule out a network issue. I left the tablet switched off for a while, when turned on it had my Spanish location but went back to Missouri within a couple of minutes. I can set the time manually but the location thing is a real pisser, any internet searches give results from the US. I've run out of ideas on how to fix it, anyone else got any suggestions?
    Has thanked: 543 times
    Been thanked: 7697 times
    Re: My tablet thinks it's in the USA
    You've been hacked by Russia.
    Burn it with fire.
    If you're not up for that yourself, for only £500 plus expenses I could help.
    That's what I think, where do I send the money?
    Has thanked: 2466 times
    Been thanked: 3769 times
    Pirahna wrote: Tue Dec 03, 2024 8:18 pm That's what I think, where do I send the money?
    Obvs... :)
    Seriously though, folks. I assume you're running Windows 10 or 11? Perhaps try switching your GPS location off?
    To turn on or off GPS location in Windows 11, you can do the following:
    Go to Start
    Select Settings
    Select Privacy
    Select Location
    Toggle the Location services switch to turn it on or off
    mangocrazy wrote: Tue Dec 03, 2024 8:37 pm I assume you're running Windows 10 or 11?
    It's Android.
    Pirahna wrote: Tue Dec 03, 2024 8:39 pm
    It's Android.
    Is it called Ash, don't trust it!
    It's Android.
    In which case, I have no idea. But I suspect it has somehow fixed its GPS coordinates to Hicksville USA, and you will need to find where in the settings this can be altered. I'd guess that its 'home' GPS coordinates are fixed (wrongly) and need to be toggled so that your actual GPS coordinates are picked up.
    Screwdriver
    Has thanked: 268 times
    Been thanked: 772 times
    Post by Screwdriver »
    Not using a VPN are you?
    Plato
    Screwdriver wrote: Tue Dec 03, 2024 10:05 pm Not using a VPN are you?
    No VPN. I've spent two days searching for a fix and been through every conceivable setting on the thing without success. There's is very little stored on it, I think I'll factory reset it.
    Screwdriver
    Don't be so quick to dismiss network/router issue. You may have a different connection using the tablet than the other devices on the same network.
    Plato
    Pirahna wrote: Tue Dec 03, 2024 10:48 pm
    Factory reset would be a good starting point. I can't see how it could realistically be a network/routing issue given that your ISP will be in Spain, but if the problem persists after a factory reset, then nothing is off the table.
    Screwdriver wrote: Tue Dec 03, 2024 10:51 pm Don't be so quick to dismiss network/router issue. You may have a different connection using the tablet than the other devices on the same network.
    My ISP is Starlink, there's not much you can do with the router. My internet facing IP address is a regional Spanish one, nothing funny there either. The tablet is a Samsung, wifey has an older one with no problems, there's also two Android phones with no issues.
    Screwdriver
    Pirahna wrote: Tue Dec 03, 2024 11:06 pm
    Sounds like your device is being given GPS data based on the location of the nearest ground based network address. For Starlink that could be anywhere! Way beyond my limited knowledge outside the Apple sandbox (Apple uses "location services" which can be user set for each application ie use WiFi or GPS or Apple database). Does the device even have GPS built in?
    Anyhow agree with above. Hard reset....
    Plato
    Factory reset done and it's back to normal.
    But I've already filled the jerry can!
    There's probably a bloke in Clever, Missouri who's wondering why every app on his device is talking Spanish... :D
    The tablet has just returned from a trip to Missouri, seems OK again now though.
    From yesterdays Google Timeline
    Pirahna wrote: Wed Dec 04, 2024 9:59 pm From yesterdays Google Timeline
    Oh, you, pretty Chitty Bang Bang
    Chitty Chitty Bang Bang, we love you
