Winter gloves -
Has thanked: 16222 times
Been thanked: 3928 times
Winter gloves -
Are there any that aren't massively thick and solid? I seem to remember the last ones I had were too chunky for me to use well.
I have used summer gloves in the past with a (too) big pair of ski gloves over the top - which did work but I can't find those gloves!
The gloves I use are shorties cos normal ones never fit me. But damn I had cold fingers today. I had summer shorties plus some liners; winter bike liner thingies, pretty old but have really worked well until this morning - but this morning was the coldest long ride I've done since being back to riding!!
I am reasonably sure that the nerve damage in my right arm made the issue worse just cos the right hand was way worse than the left (massive amounts of pins and needles in the three fingers from index to ring on the right hand). But still - gotta be a way!!
Plan is to try and get a 390 Duke in about February (if I pass my highway code and end up with a permanent contract!) so will shop for better winter gear then too.
My hands are pretty small really but the palm size needs my fingers to be longer, if that makes sense?!! So, possibly normal sized hands but short fingers which means gloves are a total bastard to fit :( :(
Just kinda wondering aloud at the mo :D :D
Has thanked: 9834 times
Been thanked: 10147 times
Re: Winter gloves -
Heated stuff is great. I've a pair of Keis which are not much more bulky feeling than my Summer gloves.
They've really gone up in price,I didn't pay this sort of money for mine. :shock:
https://www.sportsbikeshop.co.uk/motorc ... rod/469738
Re: Winter gloves -
Skub wrote: Wed Nov 13, 2024 7:40 pm Heated stuff is great. I've a pair of Keis which are not much more bulky feeling than my Summer gloves.
Hadn't thought of heated gloves! Figured they'd be too bulky.
Will have to find a shop to try some cos no way can I risk sizing at that price!!
TBF, if I do end up with a 390 again, I'll be putting guards on the bars (hand guards? Wind guards? Brake lever guard/s?) so that will help massively. But equally, I'd be riding that in the proper cold!! Today wasn't really 'that' cold - but it was on a moto :lol: :lol: :lol:
Re: Winter gloves -
Noggin wrote: Wed Nov 13, 2024 7:45 pm Hadn't thought of heated gloves! Figured they'd be too bulky.
The one great thing about Sportsbike shop,is they are really good with returns. That gives you some leeway if the fit isn't right. Glove sizing is mad anyway,so ya need to try.
Has thanked: 7819 times
Been thanked: 2530 times
Re: Winter gloves -
Bit expensive maybe, but BMW make a pair of gloves that are waterproof and lined, but only lined thinly on the palm side, so they might work for you in terms of being less bulky.
They're actually designed for using with heated grips, but the thin palm makes them far less bulky to wear.
Unfortunately they've just changed the names of everything they sell and i can't figure out which pair it is.
Ian
Has thanked: 600 times
Been thanked: 319 times
Re: Winter gloves -
Post by Ian »
Muffs are ace if you can get used to them, you can wear a lighter glove under them and stay warm.
Re: Winter gloves -
Skub wrote: Wed Nov 13, 2024 8:03 pm
Not sure it would work from here but I’ll have a look 🤞🏻🤞🏻
Has thanked: 6198 times
Been thanked: 5088 times
Re: Winter gloves -
A heated waistcoat will always be warmer than just gloves because you're heating the body core. That keeps your hands warm. Also means you don't have to wear loads of layers.
It's quite surprising how much heat they provide - that thermals etc can never maintain.
Easy to transfer between bikes, just a lead to wire in (unless the bike has a canbus).
Been thanked: 7535 times
Re: Winter gloves -
Non-Bike heated kit is often cheaper than stuff designed for bikers.
There's plenty of heated site wear available, the main difference is it's all battery powered rather than designed to be wired to a bike.
Re: Winter gloves -
Horse wrote: Wed Nov 13, 2024 9:10 pm A heated waistcoat will always be warmer than just gloves because you're heating the body core. That keeps your hands warm. Also means you don't have to wear loads of layers.
Very true.
Re: Winter gloves -
KungFooBob wrote: Wed Nov 13, 2024 9:12 pm Non-Bike heated kit is often cheaper than stuff designed for bikers.
Some stuff like that is the same as bike gear, just not with the branding.
If the battery is the right voltage then you may even be able to wire it to the bike.
Re: Winter gloves -
RST Paragons or heated grips
Re: Winter gloves -
My EXO2 had a battery too ;) But it's a fair point. IIRC @The Spin Doctor bought a non-biker one.
Re: Winter gloves -
I had deliberately layered up pretty well, thermal ski top, t-shirt, thick sweatshirt and textile jacket (although minus lining as I can’t find it - but that left the space for the layers!!)
Also a neck tube with the thermal/fllece bit around the neck and the thin bit under the lid. Plus another one with no fleece over my dodgy shoulder!!
I do think that without the layers, I wouldn’t have managed the two hour long bits of the journey!
And I did that cos of your past comments about keeping the body warm to help keep the extremities warm!!
I’m tempted to get a heated waistcoat and put guards on the bars (if it’s a 390) to keep the wind off my hands. If I ever get a sports bike I’m not gonna ride it in the same conditions as yesterday!!!
Le_Fromage_Grande wrote: Wed Nov 13, 2024 10:02 pm RST Paragons or heated grips
Thank you. Heated grips haven’t been an option on the bike I’ve been using (not mine!!) but definitely something I’ll look at when I eventually have my own 👍🏻.
Will make a list and head to a bike shop in spring to do some trying on of gloves 😁
