The crf1000.....again!
- Has thanked: 85 times
- Been thanked: 687 times
It's back!
Needs the 16k service 'its a biggy' he said.
All fluids, oil filters, valve check and a wipe down with an oily rag!
Should have rtfm before agreeing to it!
Remove bodywork, tank and airbox......that's 1½ hrs
Ok, there's a tray of coils sitting above the rocker cover. Wriggle here, wriggle there, nope not coming out with the injectors in the way.....off come the injectors. Bit more wriggling.....nope, not coming out unless I free the coils.
I can only see 3 plug caps......4 behind a radiator......off with the rads then!
Now we have access to the rocker box.....off she comes easy peasy!
Check valves......all in spec! Cock....or huzzah
Just have to pop it all back together now, which usually takes twice as long as pulling it apart!
- Has thanked: 5449 times
- Been thanked: 13085 times
Re: The crf1000.....again!
Has potential as a thread, needs more pics and the whole topic not to be rushed
It's a paying punter, so unfortunately it will be done expeditiously, but photos will be taken just to show how bloody awkward it is!
Oh fuckity fuckity fuck fuck!
Lobbed it all back together, which required a partial re build as one of the injector connectors was inaccessible once TB are fitted......and it was a 'where does this wire go' moment
Eventually got the tank back on......which was a struggle, fire up lovely, but a fair bit of smoke, it'll clear soon.....nope!
Hmmm, smells like burning oil. Stop the motor and have a look.
Oil is dripping down the engine......aaarrrrrrggghhhhh
So pull it all down again.......rocker cover not sitting quite flush, have I mentioned 'fuck' yet!
Seems a dowel has dropped a wee bit which just stops the gasket sealing.....deep joy!
So darkness has stopped playing, but I'm now getting good at putting the coils back in!
Serious amount of rust inside the headstock
Worlds longest spark plug thread....BR7HS for comparison.
Spot the difference
Back together again, no unintentional leaks this time!
So just have to drop the oil.....2 drain plugs and 2 filters, one of which is partially obscured by the crash bar! On the other side, the dipstick is blocked in by the NERF bars!!!!
All nicely thought out thenSadlonelygit wrote: ↑Tue Oct 29, 2024 12:29 pm Back together again, no unintentional leaks this time!
- Has thanked: 15947 times
- Been thanked: 10243 times
You qualify as a specialist now and everyone will be bringing them to you!
- Has thanked: 1295 times
- Been thanked: 872 times
- Been thanked: 7526 times
Bucket of leftover bits.
Confused by the grabnut........only used for the screen, and they're all there!
Actually missing 2 screws, but I know why!
- IMG_20241029_175718.jpg (600.45 KiB) Viewed 398 times
You'll have to excuse the hard of hearing...is that a 4th coil hiding or something else? I've got a cbf600 how many an I gonna have;)
Sorry new to all this lark, just interested,
Thanks C
Thanks C
The screen grabnuts are notorious for falling through and putting a new one in is a lot easier than retrieving he old one. On the forums everyone advises to get spares if you're changing or just removing the screen as it's likely at least one will fall in.Sadlonelygit wrote: ↑Tue Oct 29, 2024 5:09 pm Bucket of leftover bits.
But ...but .....but.......it's been main dealer serviced from newTaipan wrote: ↑Wed Oct 30, 2024 7:38 amThe screen grabnuts are notorious for falling through and putting a new one in is a lot easier than retrieving he old one. On the forums everyone advises to get spares if you're changing or just removing the screen as it's likely at least one will fall in.Sadlonelygit wrote: ↑Tue Oct 29, 2024 5:09 pm Bucket of leftover bits.
