Talk to me about boost plugs!
Sadlonelygit
Has thanked: 77 times
Been thanked: 640 times
Post by Sadlonelygit »
Found one on the crf of doom! Sits in line from the maf sensor in the airport, so guessing it just fiddles the signal to the ecu.
Thing is, there's a fair bit of oil in the airbox, both drain hoses were full. Connected or just usual modern emissions malarkey.
Your thoughts as always are appreciated
Ditchfinder
Has thanked: 594 times
Been thanked: 671 times
Re: Talk to me about boost plugs!
Post by Ditchfinder »
From what I understand all they do is alter the air intake temp to try and make the ECU pump more fuel to richen mixture at closed throttle. Shouldn't affect oil in anyway.
Has thanked: 999 times
Been thanked: 1738 times
I had one on a gs1150. It modified a temp sensor's input to make the standard map run less lean and therefore more smooth. It worked for about a week or so and then the map adjusted and it was the same jerky shitebox as before. Shouldn't have any effect on oil in the airbox.
Has thanked: 1792 times
Been thanked: 1434 times
dern wrote: Mon Oct 28, 2024 1:38 pm I had one on a gs1150. It modified a temp sensor's input to make the standard map run less lean and therefore more smooth. It worked for about a week or so and then the map adjusted and it was the same jerky shitebox as before. Shouldn't have any effect on oil in the airbox.
Interesting - I run one on my Scrambler because the 1200 runs very lean. When I first put it on, I swear it made a difference. However I am pretty convinced that now it doesn't!
Has thanked: 7629 times
Been thanked: 2458 times
The BMW Motronic is a closed loop system, so anything that just tinkers with a single sensor tends to get ignored fairly quickly.
Best solution for them is a complete new map.
Has thanked: 4296 times
Been thanked: 2812 times
Oil in the airbox sounds more like overfilled oil, no? Or something like that. I seem to recall wheelies used to dump oil in the air box of LC4 KTMs as well.
Supermofo wrote: Mon Oct 28, 2024 3:18 pm Oil in the airbox sounds more like overfilled oil, no? Or something like that. I seem to recall wheelies used to dump oil in the air box of LC4 KTMs as well.
Yep - airbox is usually where the engine breather exits.
Buckaroo
Has thanked: 705 times
Been thanked: 673 times
Post by Buckaroo »
Like @dern said. I put one on my F800R. Worked for a while and then back to the usual stutter.
Has thanked: 2532 times
Been thanked: 6140 times
If your bike has the big dustbin cat (no idea if the OP does) then it'll be closed loop fueling, so anything wedged in to try and "fool" the ECU will be ignored/adjusted out pretty quick - withina couple of miles quick. Or it'll just make the check engine light come on.
Has thanked: 15665 times
Been thanked: 10083 times
I got one for my F800R only to find it already had one! D'oh! I unplugged it for a few hundred miles and plugged it back in and it was better, but I knew it was going to revert0 to its base settings again, so I had the ECU remapped and it was probably the best fuelling bike i've ever owned.
I put one on my KTM 690 Duke and it helped, but didnt solve the jerkiness.
Scootabout
Has thanked: 475 times
Been thanked: 308 times
Post by Scootabout »
When I first got the V85TT it used to pink, quite badly, when hot. I looked into various solutions, including booster plugs. In the end I didn't need any, as there was an official ECU remap due, which the dealer did. This solved the problem.
Others have used third party mapping solutions. The names Upmap and Beetle Maps spring to mind.
Ditchfinder
Beetle maps are very well known in the Guzzi fraternity
roadster
Has thanked: 13 times
Been thanked: 142 times
Post by roadster »
There could be some connection between over-fuelling and oil in the airbox if the oil smells of fuel and the level seems to be high but then falls after a long run. Namely that unburnt fuel washes off the oil on piston scrapper rings and blow-by carries fuel into the crankcase. Oil will smell of petrol and there will be excessive crankcase pressure blowing out through the breather when disconnected.
Dickyboy
Has thanked: 478 times
Been thanked: 342 times
Post by Dickyboy »
Still found a proper remap at Dave Wood Racing far better for my 1200 sport, considerably more expensive than a beetle map grant you, but +5bhp in the midrange & a lot smoother.
