Brake pads ?
Has thanked: 1749 times
Been thanked: 2085 times
Brake pads ?
The GS and the MT09 are both in need. GS needs front and back, linked brakes don't arf eat rear pads, already changed once. MT only needs front and is mainly used for trackdays .
Any recommendations for both. 🍻
Has thanked: 2407 times
Been thanked: 3635 times
Re: Brake pads ?
SBS RST front pads seem to be favourite for regular trackday use.
Has thanked: 5452 times
Been thanked: 13097 times
Re: Brake pads ?
If Galfer pads are half as good on motorbikes as they are on MTB then I'd try them. Their MTB pads are astounding
Re: Brake pads ?
OEM pads, they cost twice as much, but last twice as long and match your brake discs
Has thanked: 599 times
Been thanked: 2448 times
Re: Brake pads ?
weeksy wrote: Sun Sep 22, 2024 12:27 pm If Galfer pads are half as good on motorbikes as they are on MTB then I'd try them. Their MTB pads are astounding
I'll let you know next year as I'm not loving the EBC HH sintered ones I put in this year, and figure I should see what Galfer pads are like with Galfer discs
Has thanked: 15964 times
Been thanked: 10249 times
Re: Brake pads ?
Depends on your riding style. Sintered pads work best with heat and work increasingly well when hot. So if you're out hooning about or doing track days, then sintered are your go to pads. But, they are wooden as fook compared to organic in normal riding and I much prefer organic pads for my riding. Sad to see lot of Hondas OEM pads are shifting to sintered only.
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Re: Brake pads ?
Post by Trinity765 »
Another vote for SBS. I had the RS in my last Street Triple and then the Speed Twin and they were great.
Has thanked: 9834 times
Been thanked: 10147 times
Re: Brake pads ?
Almost anything apart from EBC.
Been thanked: 7535 times
Re: Brake pads ?
Fit any brand, it's not like you're a girl who uses the 'coward lever', are you?
Re: Brake pads ?
Taipan wrote: Thu Oct 03, 2024 11:14 pm Depends on your riding style. Sintered pads work best with heat and work increasingly well when hot. So if you're out hooning about or doing track days, then sintered are your go to pads. But, they are wooden as fook compared to organic in normal riding and I much prefer organic pads for my riding. Sad to see lot of Hondas OEM pads are shifting to sintered only.
Sintered pads are also a Bad Thing if you're using cast iron or (more commonly) ductile iron rotors. Sintered pads have a very unpleasant feel with iron rotors, very grabby at low speed, and wear the rotors out very, very quickly. But as virtually all bikes these days are fitted with stainless steel rotors, that's not so much of a problem.
The problem, in my opinion, is finding decent organic pads these days. As my learned fiend Mr Tiepin sez, most manufacturers are quietly dropping organic pads and pushing sintered pads as the default. Less stock to carry, I guess.
Re: Brake pads ?
I used Ferodo Platinums when I had ductile iron discs.
PFM only recommend one brand of sintered pads, Mintex. I used them once, they didn't wear this discs to bad, but they were totally done after one and a half trackdays, good job I took a spare set.
Has thanked: 2248 times
Been thanked: 1242 times
Re: Brake pads ?
Skub wrote: Fri Oct 04, 2024 9:23 am Almost anything apart from EBC.
GoldFren? :lol:
My BMW came with those, explained it's reluctance to stop - I fitted EBC sintered which I actually quite like.
Re: Brake pads ?
I fitted some Armstrong pads to my DR250, they make Goldfren feel like Brembo!
Re: Brake pads ?
KungFooBob wrote: Fri Oct 04, 2024 11:28 am I fitted some Armstrong pads to my DR250, they make Goldfren feel like Brembo!
Yeah - years ago I purchased a GSX-R1000K4 and the guy had fitted Armstrong wavies and pads, they soon went in the skip.....
Re: Brake pads ?
KungFooBob wrote: Fri Oct 04, 2024 10:40 am I used Ferodo Platinums when I had ductile iron discs.
I've found it quite difficult to get hold of Ferodo Platinum pads in the fitting I need. At present I'm running PFC95 compound but they're very pricey and equally hard to get hold of here in the UK. I'm reduced to scouring USA Ebay, getting them sent to my sister in law and she forwards them to me. It's not exactly a sustainable solution...
