Mothers
Has thanked: 9819 times
Been thanked: 10144 times
Mothers
Most modern bikes don't have chrome or alloy to polish,so this recommendation is mainly for classics or retros such as Royal Oilfield.
For anything except chrome,this stuff knocks the likes of Autosol and Belgom Alu into a cocked hat,whatever that means.
https://www.ebay.co.uk/itm/255903291155
Not a great deal of time was spent rubbing the H1a today.
Tricky
Has thanked: 2564 times
Been thanked: 2680 times
Re: Mothers
Post by Tricky »
Cheers - I've been a lifelong solvol man and never heard of this before , but I know looking at your disgustingly shiny smokers it'll be decent stuff , so have just ordered a tub , mainly for all the lovely 1970s ally on the Laverda :thumbup:
Re: Mothers
Tricky wrote: Thu Oct 03, 2024 7:51 pm Cheers - I've been a lifelong solvol man and never heard of this before , but I know looking at your disgustingly shiny smokers it'll be decent stuff , so have just ordered a tub , mainly for all the lovely 1970s ally on the Laverda :thumbup:
It's well known in the US,but catching on here too. A lot less effort required than solvol and a noticeably better result.
Has thanked: 1507 times
Been thanked: 1410 times
Re: Mothers
It doesn't keep & turns into crap once it's opened, You'll likely end up throwing most of it away.
Has thanked: 2550 times
Been thanked: 6241 times
Re: Mothers
I use Peek, for no particular reason more than the fact i could find a big tin of that but not of autosol.
BTW, real, highly toxic, chrome is way better than the modern stuff IMO.
Re: Mothers
ZRX61 wrote: Thu Oct 03, 2024 8:53 pm It doesn't keep & turns into crap once it's opened, You'll likely end up throwing most of it away.
Maybe warmer where you are though? :silent:
Re: Mothers
Skub wrote: Fri Oct 04, 2024 9:20 am Maybe warmer where you are though? :silent:
True, but the heat doesn't affect other metal polishes & I probably have a half dozen kinds.
Re: Mothers
ZRX61 wrote: Fri Oct 04, 2024 3:28 pm
Any recommendations from your years of rubbing?
Has thanked: 6375 times
Been thanked: 4746 times
Re: Mothers
I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort. :(
PS Every time I see this thread an image of Frank Zappa pops into my head. :D
Has thanked: 7810 times
Been thanked: 2527 times
Re: Mothers
Count Steer wrote: Fri Oct 04, 2024 4:21 pm I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort. :(
Solvol requires a reasonable amount of effort, and also needs to be used regularly for best results. It's good for getting something already clean and shiny, properly clean and shiny. It also works best on old chrome and nickel plating, modern stuff doesn't get the same finish.
Re: Mothers
Rockburner wrote: Fri Oct 04, 2024 4:24 pm
So what works best on alloy that may have got a little, erm, furry...like the bottom end of BMW forks? :D
Re: Mothers
Count Steer wrote: Fri Oct 04, 2024 4:28 pm
Replacement.
Re: Mothers
Skub wrote: Fri Oct 04, 2024 4:14 pm Any recommendations from your years of rubbing?
Still Solvol :)
Re: Mothers
I use minimal amounts on a folded blue paper shop towel. I have other stuff to use with power tools.
Re: Mothers
Count Steer wrote: Fri Oct 04, 2024 4:21 pm PS Every time I see this thread an image of Frank Zappa pops into my head. :D
That's very inventive. :thumbup:
Sadlonelygit
Has thanked: 85 times
Been thanked: 687 times
Re: Mothers
Post by Sadlonelygit »
My old z1000e used to get autosol'd to death. Shiniest outer float bowls known to man. Clutch/alternator/ pickups were also quite spangly
Has thanked: 15944 times
Been thanked: 10243 times
Re: Mothers
Presumably, the air gets to it. What if you made a cartouche to put on the surface, would that not solve the problem?
