Chunky aren't they? I've got the same strimmer and, through the summer, I've taken to just lightly strimming the grass front and back + the verge, instead of mowing, and there's usually 2 or 3 lights on the battery at the end. One thing I would have liked on it is a shoulder strap. It's not overly heavy but a strap makes life easier. (Had a petrol strimmer/brush cutter before and that had one - the weight just sort of disappears).
Battery Garden Tools
- Has thanked: 6375 times
- Been thanked: 4746 times
Re: Battery Garden Tools
- Has thanked: 599 times
- Been thanked: 2428 times
Weight was considered, not so much for me but the wife will use them, s'why I went Ak10's for the handheld stuff and AK20's for the mower.
If needs be I'll get a strap / harness lashed up for her.
1 point of annoyance, the strimmer and hedge cutter both have 2 safety interlocks.
The strimmer I can live with as 1 remains engaged after you let the off the power, so you're only needing to apply 1 once you're up and running, the hedge cutter however is set up so both reset when power is released, or after one of the safety locks is released, so one of those will need a crafty cable tie to defeat it permanently, otherwise one handed use is not possible.
- Has thanked: 6186 times
- Been thanked: 5087 times
I rigged up one for our Ryobi. Used a wide suitcase 'security' strap.Count Steer wrote: ↑Wed Jul 31, 2024 8:09 am. One thing I would have liked on it is a shoulder strap. It's not overly heavy but a strap makes life easier.
- Has thanked: 15947 times
- Been thanked: 10243 times
I have a selection of makita tools so decided to buy a 36v makita lawnmower. I wish I hadn't as its pretty shit. Its okay if you already have short grass and you want to just keep it down, but for hacking into anything overgrown its useless.
Most lawn mowers aren't for hacking down the undergrowth/overgrown areas with a bit of grass in.
Should've bought a brush cutter.
Having said that I do use my mains powered big Bosch rotary on the, erm, eco-natural bit of my 'grassy area'. (I actually haven't used the mower on the back 'lawn' at all this year, just the strimmer. The little mains powered Bosch has been used twice on the front lawn and verge and, again, the strimmer has been used most of the time. Despite all the rain grass hasn't grown as much as previous years. Weeds and moss have done well though.
- Has thanked: 7810 times
- Been thanked: 2527 times
The knackered old Briggs& Stratton powered Mount field we inherited with the house is still better than any brush cutter, (well, as long as the ground is relatively flat....)Count Steer wrote: ↑Wed Sep 25, 2024 5:28 pm Most lawn mowers aren't for hacking down the undergrowth/overgrown areas with a bit of grass in.
Go slower, with a higher cut. Listen; if it sounds like it's slowing, pull back, then more slowly forwards.
Battery electric doesn't have the umph of petrol.
Oh I know how to make it work, but with a decent mower you don't have to mess about like that. It does mke anice finishing mower though, but it only supplements my petrol one in that role.
