Peaked helmets
- Ditchfinder
- Has thanked: 622 times
- Been thanked: 692 times
Peaked helmets
Now I've got a winter shitbox for commuting on I've come up against low sun conditions on my way home on a few occasions.
Do peaked helmets solve this problem?
If so what's good and not too spendy for a country lane 20 min commute?
Speeds not likely to exceed 50mph so noise shouldn't be too bad, this bike is noisier than wind anyway
- Been thanked: 7536 times
- Has thanked: 2407 times
- Been thanked: 3635 times
Re: Peaked helmets
I'd suggest that a helmet with integral sun visor is probably your best bet.
https://www.sportsbikeshop.co.uk/motorc ... sun+visors
I have to say I've no experience with sun visor helmets, but have considered them from time to time.
- Ditchfinder
Re: Peaked helmets
So double down on a visor and peak?
Something like this ?https://www.sportsbikeshop.co.uk/motorc ... rod/687896
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
- ChrisW
- Has thanked: 2915 times
- Been thanked: 2060 times
Re: Peaked helmets
I was going to suggest something like the Airoh Commander etc. but - £55 for a bit of a commute for a while? Grab it with both hands. The peak's as well vented as any of the other pricier ones from the look of it.Ditchfinder wrote: ↑Tue Sep 24, 2024 7:22 pm So double down on a visor and peak?
- gremlin
- Has thanked: 810 times
- Been thanked: 4805 times
Re: Peaked helmets
I have Shoei one. I find it very agreeable. The internal visor works well and the Sena comms works well.mangocrazy wrote: ↑Tue Sep 24, 2024 7:20 pm I'd suggest that a helmet with integral sun visor is probably your best bet.
https://www.motolegends.com/motorcycle- ... i/gt-air-2
Yet to really figure the point of a peaked helmet, other than to complete the 'adventure' look.
- Has thanked: 86 times
- Been thanked: 691 times
- Has thanked: 599 times
- Been thanked: 2449 times
Re: Peaked helmets
I'd not go for the internal visor, based solely on my opinion of a race dark visor not being dark enough, and it adding an extra layer to fog up, but electrical tape will work.
- wheelnut
- Has thanked: 908 times
- Been thanked: 1001 times
Re: Peaked helmets
Used a tour x4 for years - never had an issue with wind and found it useful for glare.
An internal sun visor would be useful but arai done do them.
- Cousin Jack
- Has thanked: 2554 times
- Been thanked: 2287 times
Re: Peaked helmets
I have 2 helmets, one peaked, one not, otherwise almost identical.
The peak is occasionally useful for shading, but both have internal sun visors too. A strip of black tape is probably the best solution to really bad low sun glare.
The extra drag/wind of a peak is just not an issue. I don't feel any difference, even at motorway speeds.
- Has thanked: 6381 times
- Been thanked: 4762 times
Re: Peaked helmets
I was about to say Schuberth....then I saw the 'not too spendy'.
- Has thanked: 7820 times
- Been thanked: 2530 times
Re: Peaked helmets
Tape.
I used to use two visors (clear for heading north, dark for heading east), but the simplest answer is tape.
- Has thanked: 6198 times
- Been thanked: 5088 times
Re: Peaked helmets
KungFooBob wrote: ↑Tue Sep 24, 2024 7:18 pm Cheapest option is some black tape across the top of your existing visor.
Yup, ^ that
Get a lid that's comfy, stick tape on its visor. Lower edge just above eye level. Then you just need to dip your head slightly to block low sun. Gives you clear view ahead
Sunglasses darken everything.
Drop down inner visors aren't dark enough to block sunlight glare.
- Ditchfinder
Re: Peaked helmets
Well I've ordered a peaky lid with internal visor and I will test it against my old lid with tape and report back (when it stops raining)
- Has thanked: 16228 times
- Been thanked: 3928 times
Re: Peaked helmets
I've never been keen on sunglasses in a lid. I have to wear glasses, but with a dark visor I can flip it up in a very shady area or one of the many tunnels, with sunglasses it feels like I'm a bit screwed on options if in an area that isn't 100% sunny all the time!
I did realise that I'll have to try the black tape thingy on my clear visor the other day - it had been a dull possibly rainy day when I headed down but sunny when I went back home. The clear visor was definitely not ideal !! I've never tried the tap, so need to do that next time I have the clear visor on just to lessen the blindingness!! LOL
Re: Peaked helmets
Has anyone ever made graduated tinted visors (dark at the top, like some windscreens)? Seems a bit of an obvs solution instead of slapping tape on things.
Re: Peaked helmets
They used to be available, but:Count Steer wrote: ↑Thu Sep 26, 2024 8:49 am Has anyone ever made graduated tinted visors (dark at the top, like some windscreens)? Seems a bit of an obvs solution instead of slapping tape on things.
- 'Newer' (25 years?) visor regs mandated minimum light transmission. So really dark visors are 'track use only', and graduated tint would fail too.
- You can apply the tape at the height appropriate for your eyes. Can't do that with a graduated tint
- Tint (as with sunglasses) won't block sunlight from your eyes. They will still react and reduce view through the untinted section.
Tape. I used cheapo beige masking tape, because I had some handy. Use expensive luxury plastic insulation tape if you must
Re: Peaked helmets
Kind of ironic that a a graduated visor with a heavy tint at the top is forbidden, so the work-around is to put a strip of opaque tape on. Hard to imagine why the first option is verboten but the second one isn't.Horse wrote: ↑Thu Sep 26, 2024 9:15 amThey used to be available, but:Count Steer wrote: ↑Thu Sep 26, 2024 8:49 am Has anyone ever made graduated tinted visors (dark at the top, like some windscreens)? Seems a bit of an obvs solution instead of slapping tape on things.
