- Has thanked: 1446 times
- Been thanked: 1331 times
- gremlin
- Has thanked: 776 times
- Been thanked: 4515 times
Rolling blackouts here again, but Benito Newsolini hasn't told people to stop charging their EV's yet.
And this happened:
https://www.10news.com/news/local-news/ ... nk-storage
Apparently it could burn for up to 48 hours..
And this happened:
- Has thanked: 1326 times
- Been thanked: 1652 times
Lots of modern cats are pretty much covered in cameras nowadays, it won't just be Teslas.
Little bit like police asking about home wifi modems so they can check for connections made in relation to murder cases and Ring doorbell footage.
- Has thanked: 2611 times
- Been thanked: 6014 times
When I set up the factory fit dash cam in my car I had to acknowledge a note which said (paraphrasing) "this thing records everything, it can be used against you as well".
It takes 360° photos of its surroundings if you jiggle the car too.
Nothing to do with being an EV or not.
The cam mounts on the ZRX11 & ZX11 are located so not one part of the bike or rider is visible in the footage.Mr. Dazzle wrote: ↑Sun Sep 08, 2024 4:22 pm When I set up the factory fit dash cam in my car I had to acknowledge a note which said (paraphrasing) "this thing records everything, it can be used against you as well".
The F350 has three cams: Regular dash cam on the windshield by the mirror, another in the rear window connected to the first & a back up cam that comes on when I put it in reverse.
The Explorer ST has at least 4 cameras.
If the worst happened and you were involved in a big accident...someone else died, the police seized your bike at the scene etc.
Do you really think your face not being visible on the cam footage would save you?
Mr car on the other hand would totally narc on me
It's more about being able to post videos online without waiting a year so I don't get my collar felt. Luckily the bike cam doesn't have a velocity read out, but the F350 from cam does.... which has lead me to trying to set the high score (98mph so far)Mr. Dazzle wrote: ↑Sun Sep 08, 2024 5:58 pm If the worst happened and you were involved in a big accident...someone else died, the police seized your bike at the scene etc.
- Pirahna
- Has thanked: 1773 times
- Been thanked: 1109 times
Various reports in the last 12 months have suggested the write-off rate for EVs is exceptionally high due to unaffordable repair costs. However, Cap Hpi says petrol and diesel cars are written off at over double the rate of EVs, based on figures for the last decade.
https://www.thisismoney.co.uk/money/ele ... -cars.html
- Has thanked: 15606 times
- Been thanked: 9850 times
If the SS (Starmers Stasi) pull you for suspicion of road based naughtiness and see you have a camera they will confiscate it to review the footage so the can nick you for anything else as well as what they stopped you for. Also most of our regional forces have a "grassline" where you can submit your own camera evidence for the SS to nick you. When I did a drivers awareness course (Damn that Ducati ) the host said Plod prosecute more people through public submitted camera clips than their own!ZRX61 wrote: ↑Sun Sep 08, 2024 5:43 pmThe cam mounts on the ZRX11 & ZX11 are located so not one part of the bike or rider is visible in the footage.Mr. Dazzle wrote: ↑Sun Sep 08, 2024 4:22 pm When I set up the factory fit dash cam in my car I had to acknowledge a note which said (paraphrasing) "this thing records everything, it can be used against you as well".
That's not hugely surprising, the public have loads more cameras in loads more places than plod do now.
I've never seen the clips or know exactly what people have been nicked for, but with a public camera they aren't calibrated , which is qualified when you get nicked by plod for speeding.Mr. Dazzle wrote: ↑Sat Sep 21, 2024 10:54 am That's not hugely surprising, the public have loads more cameras in loads more places than plod do now.
- Has thanked: 852 times
- Been thanked: 1226 times
Considering the average value of diesel and petrol cars will much lower than EVs then both statements could be true, this looks like someone is misusing statistics.Pirahna wrote: ↑Sat Sep 21, 2024 6:29 am Various reports in the last 12 months have suggested the write-off rate for EVs is exceptionally high due to unaffordable repair costs. However, Cap Hpi says petrol and diesel cars are written off at over double the rate of EVs, based on figures for the last decade.
I wouldn't be so sure.Taipan wrote: ↑Sat Sep 21, 2024 11:44 amI've never seen the clips or know exactly what people have been nicked for, but with a public camera they aren't calibrated , which is qualified when you get nicked by plod for speeding.Mr. Dazzle wrote: ↑Sat Sep 21, 2024 10:54 am That's not hugely surprising, the public have loads more cameras in loads more places than plod do now.
The factory one in my car for example includes the speed and location at the bottom, taken from the cars own systems.
The speedo in particular has pretty stringent requirements (both by law and by the OEMs own internal rules) so i wouldn't like to rely on a "his speedo ain't calibrated" argument.
Besides, if your vid shows 150mph a small calibration error is probably irrelevant
You also don't need speed to nick someone for driving in a bus lane, crossing lines etc etc. of course.
- Has thanked: 5945 times
- Been thanked: 4933 times
If you mean 'calibrated for speed', that's not a problem. Helpfully, white line markings are installed to defined sizes and intervals. So distance can be identified. They ask for original recordings, so frame rate will be known. Therefore, distance and time give speed.
If the dashcam even more helpfully gives gps and timestamp, then the noose tightens ...
However, recordings submitted are more probably more likely to be for the standard of driving rather than speed.
Good point on time...GPSs derived time is extremely accurate, down to the nanosecond, so if you have that on the vid you're held by the short and curlys.
But dashcam GPS location may not be so accurate!Mr. Dazzle wrote: ↑Sat Sep 21, 2024 12:09 pm Good point on time...GPSs derived time is extremely accurate, down to the nanosecond, so if you have that on the vid you're held by the short and curlys.
I was chatting to an accident investigator a few years ago, as dashcams were becoming much more common.
They'd had one instance of a car moving across a road, post-crash.
Well they know the location by knowing the time, that's how they work.
They're typically down to about +/-3m in consumer GPS though right, so it's not surprising they'd still drift around a bit even when stopped.
For a work trial, I had 3 GPS loggers together.
Marked the positions of several items. Two gave the same position, the third was way out.
Luckily, it wasn't a key element of the trial!
- Potter
- Has thanked: 2216 times
- Been thanked: 4611 times
I was genuinely going to buy an EV recently, it was a Porsche Taycan Turbo, I went to look at it, test drove it and I was happy with the price, it was an £180k car, about a year old and selling for £65k, absolute bargain, I was 99% going ahead with it, but as I said on another thread I ended up buying another petrol Porsche that was in the showroom and not yet advertised, but it turned out to be a car that I really wanted and so I did a deal on that and not the EV.Taipan wrote: ↑Mon Aug 26, 2024 4:17 pm As a market indicator, revcomps have started raffling EVs again. The last tesla and taycan sold out, whereas in recent times they've been massively undersold. By way of contrast, I was talking to my motor trader neighbour yesterday and asked him if he had started selling EVs yet? He said no, they are to the second hand market what Ladas were in the early 80s!
But the point I'd like to make is the same point I heard Joe Rogan and Chris Harris make on a recent podcast - EVs are for rich people. They're expensive and completely useless for the large percentage of people that need a car and run on bangernomics theory i.e. cheap old cars that they can buy for a couple of grand maximum and run them into the ground for a few years and then buy another.
The people championing them fall into two categories, rich and can afford them, or poor and politically motivated, the latter are very unlikely to be able to afford one, but their political persuasions mean that they'll tell you why you should.
Strange bedfellows.
