Digital Tyre Pressure Gauge??
Has thanked: 10261 times
Been thanked: 6885 times
I've lost a few things recently. Bollox.
So now need a good digital tyre pressure gauge.
Waddya reckon?
Ta
Been thanked: 7526 times
Re: Digital Tyre Pressure Gauge??
I've got a cheap GT Moto one and a Halfrauds one.
They both read within 0.5 psi of each other.
The GT is easier to get on most valves, but I have to use the Halfrauds one on the GS due to the spoke/valve arrangement.
I don't think either cost more than a tenner.
Newey
Has thanked: 39 times
Been thanked: 48 times
Post by Newey »
A 0-15 psi for the dirt bike is always good to have.
Has thanked: 599 times
Been thanked: 2428 times
Halfords jobbie for me, not that it gets that much use
Newey wrote: Fri Sep 13, 2024 4:02 pm A 0-15 psi for the dirt bike is always good to have.
Yeah. Can't get digital ones here. The only one I found was too small to read small pressures accurately.
Nordboy
Has thanked: 299 times
Been thanked: 565 times
Post by Nordboy »
I always end up breaking the digital ones really quickly so i have a draper 69924 analogue with a flexible hose (you can order it without the hose). the hose is really handy for bikes as it is nice and narrow onto the valve. It holds the pressure as well so when you take it off, you can see the pressure level.
If you really wanted a digital one then ignore me :)
Nordboy wrote: Fri Sep 13, 2024 4:19 pm I always end up breaking the digital ones really quickly so i have a draper 69924 analogue with a flexible hose (you can order it without the hose). the hose is really handy for bikes as it is nice and narrow onto the valve. It holds the pressure as well so when you take it off, you can see the pressure level.
All help appreciated 👏
Has thanked: 2635 times
Been thanked: 1523 times
I just use a pencil gauge... the batteries always were flat in the digital ones whenever I needed it.
Or fit a tyre pressure monitoring kit...
Has thanked: 1814 times
Been thanked: 1163 times
I use a Topeak digital guage. Topeak is a bicycle brand but it works on other tyres as well, does both presta and schrader valves.
Eclipse
Has thanked: 37 times
Been thanked: 80 times
Post by Eclipse »
I use one of these, most convenient
https://www.amazon.co.uk/gp/product/B0C ... UTF8&psc=1
Some digital ones are tested here
The Spin Doctor wrote: Fri Sep 13, 2024 6:23 pm I just use a pencil gauge... the batteries always were flat in the digital ones whenever I needed it.
My trusty pencil gauge just failed. The screw fell out of the end :(
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
I stopped using a bespoke guage when I got a decent inflator.
Has thanked: 2550 times
Been thanked: 6241 times
DefTrap wrote: Sat Sep 14, 2024 4:45 am I stopped using a bespoke guage when I got a decent inflator.
I'd never used one of them until I borrowed my Dad's recently (he keeps one in their tow to quickly change the rear tyre pressure when on caravan holidays).
What is this magic? :D Bollox to pumping with your foot any more.
His one is self contained and charges from a ciggy lighter or bespoke power block, but all the usual suspects of battery power tool make em too I think.
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
I have a Halfords digital one which seems OK but isn't always easy to use on bike wheels. I also have a handful of the old displacement pencil types and they do last longer and have repeatable (in)accuracy over their life. Its the rotten rubber seal which can kill them. The most fragile gauges are the dial mechanical ones with aneroid style expanding chambers. Any miss handling throws them out of calibration in no time.
Has thanked: 2402 times
Been thanked: 3625 times
It's not digital (it's defiantly analogue), but it's the best tyre pressure gauge I've ever used.
https://www.ebay.co.uk/itm/266502168353
roadster
Post by roadster »
mangocrazy wrote: Sat Sep 14, 2024 12:45 pm It's not digital (it's defiantly analogue), but it's the best tyre pressure gauge I've ever used.
Yes I bought one of those RaceX ones, probably on your recommendation. Its very good so far but it won't always fit on small wheels such as scooters where discs and final drive cases or sprockets get in the way. I don't doubt that inside there is a delicate mechanism so I try to treat it with care and wouldn't leave it rattling around in a toolbox or car boot.
Yes, I treat it as you would a precision instrument. Take your point about using it on scooters or similar, I only use it on bike/car/van wheels.
Wscad
Has thanked: 7 times
Been thanked: 168 times
Post by Wscad »
Get the makita one . You already have the batteries . Buy the bare model👍
Wscad wrote: Sun Sep 15, 2024 12:09 pm Get the makita one . You already have the batteries . Buy the bare model👍
I have the Makita inflator. It always let's air out when detaching. So need a gauge ;)
Was gonna order one tonight as a mate is coming over soon.
Earlier pulled the bucket from under shelf and emptied the sponges out.
Guess what fell out? Fark. How did it get in there ? :obscene-birdiedoublered:
Still working OK 👍
