Does bump starting damage anything?
Has thanked: 2913 times
Been thanked: 2052 times
Re: Does bump starting damage anything?
If you're concerned about the bump start (and I wouldn't be) could you use the starter whilst you're rolling away?
Trust me on the bump starting thing, Vauxhall Vectra cats were about £400 20 years ago.
Nobby
Has thanked: 85 times
Been thanked: 477 times
Post by Nobby »
Yes. A Fence.
Bump starting a CZ175 on a Petrol Forecourt on the A25 between Dorking and Reigate.
Me running alongside and a mate pushing from behind.
It was chugging along almost firing , when it just took off. I and my mate did a double face plant, to look up and see the back of the piece of shit disappearing through a new bike shaped hole in a Panel Fence and down into a nettle filled ditch.
There's more to the story, but let's just say I got away with it.
Sadlonelygit
Been thanked: 688 times
Post by Sadlonelygit »
Nobby wrote: Tue Sep 03, 2024 10:45 pm Yes. A Fence.
Glad you reminded me!
X7 that belonged to a mechanically inept friend. Stopped starting on the kick for 'some' reason, so asked for a push.
I agreed to operate the controls and HE could push.
One step, two steps zzzzzzzzzzziiiiiiinnnnnnmnmnggggg
Fucking thing went vertical, then bounced off several fences, then laid down on the floor doing donuts spraying gravel everywhere!
Daft twat had fitted carb slides wrong way around!
I have many stories of him and things mechanical!
BBB
Has thanked: 292 times
Been thanked: 79 times
Post by BBB »
As others have said get a ski pass holder or similar and have your pass on your arm. Bump starting seems an unnecessary solution to the problem
