1972 Kawasaki 500 H1B
- Has thanked: 9673 times
- Been thanked: 9697 times
Re: 1972 Kawasaki 500 H1B
It's crap weather today,so I pulled off the carbs to set the fuel levels. Got the three pretty much bang on,but I'll have to start again,because when I let them sit for 10 minutes or so,two of the three needle valves are leaking,so game over until I those arrive. No point putting the carbs back on to take them off again in a few days.
On a side note,the petrol is breaking down,either the clear tubes,or the reservoir itself,as there is milky goo dripping out the end after it has been sitting. Not best pleased at that,since it's a Sealy tool specially for fuel.
- Has thanked: 10108 times
- Been thanked: 6649 times
Over the year I've had the H1a,I've gradually set it up right and it runs as nice as it's ever going to for an old stroker. Of the two it runs the best,but until I have the carbs set on the H1B,it's not a fair comparison. The A is the old engine and from 6k - 8.5k there's a real punch. The B redlines at 7.5k and has a less violent powerband.
At the moment I enjoy riding the A more than the B,but we'll see when everything is sorted,then we'll decide if they are both staying,or not.
- ChrisW
- Has thanked: 2727 times
- Been thanked: 1914 times
- Has thanked: 2318 times
- Been thanked: 3371 times
7.5k RPM on a 500cc triple is a really conservative red line. So Kawasaki detuned the 'B' motors, then? And weren't the 'A' motors detuned from the original Mach III?
The 69 - 71 bikes are the same engine wise. Some markets had CDI and some had points ignition. The UK market returned to points because the frequencies here were different from the USA and the CDI messed with UK tv and radio reception.mangocrazy wrote: ↑Sun Aug 25, 2024 7:39 pm7.5k RPM on a 500cc triple is a really conservative red line. So Kawasaki detuned the 'B' motors, then? And weren't the 'A' motors detuned from the original Mach III?
Kawasaki stopped the scalloped tank with the H1a,but the donkey is the same. The H1B was the first to see significant changes,not just styling,but with transfer port height,etc. Kawasaki touted the same bhp,but the B makes it's power a little differently. It will still pull deep into the red,but the line on my clocks starts at 7.5k. Maybe they did that to make them last a little longer.
Looking into the redline matter a bit further,it seems I was wrong. The B has the same redline as the earlier bikes,but the tacho dial on my B looks like it's one from an H2,so that would make more sense to me. I can duly ignore the first red part.mangocrazy wrote: ↑Sun Aug 25, 2024 7:39 pm 7.5k RPM on a 500cc triple is a really conservative red line.
New needle jet valves arrived today.so time to begin the process of setting the fuel level again etc.
