Cam chains
Sadlonelygit
Has thanked: 86 times
Been thanked: 691 times
Cam chains
Post by Sadlonelygit »
Can somebody explain why they fall off the crank sprocket with consummate ease, but when you try to put it back on again.........oh good luck matey!
Been thanked: 7536 times
Re: Cam chains
Its the same on a two stroke when you try to fit a blue or better powerband.
Sadlonelygit
Re: Cam chains
KungFooBob wrote: Tue Aug 20, 2024 7:43 pm Its the same on a two stroke when you try to fit a blue or better powerband.
You can only fit blue power bands onto a sucksuki, never try and fit one to a kwikasfuki
Has thanked: 10272 times
Been thanked: 6889 times
Re: Cam chains
Sadlonelygit wrote: Tue Aug 20, 2024 8:56 pm
Do you need special spark plug gaps?
Re: Cam chains
Sadlonelygit wrote: Tue Aug 20, 2024 7:41 pm Can somebody explain why they fall off the crank sprocket with consummate ease, but when you try to put it back on again.........oh good luck matey!
Never had that problem, what engine?
Sadlonelygit
Re: Cam chains
Le_Fromage_Grande wrote: Tue Aug 20, 2024 10:32 pm
KTM 125. Head is off BTW!
Could be worse, the parts department are adamant that they sent the correct parts to rebuild the head and that I must be mistaken as there is only 1 valve spring for that engine. Sent them a video of me measuring the od of the new spring, locking off the vernier, then dropping the old spring through the gap. Wire thickness is different too, no. of coils wrong and supplied In a non oe plastic bag! Dealer has fucked up somewhere! Even questioned if it was a genuine engine or not!
