Bmw r1200gs battery??
- Has thanked: 1765 times
- Been thanked: 2107 times
On Sunday the might GS stopped. Dash went wierd, speedo stopped working. Pulled into lay-by and tried to re start but no. Mate got his trailer.
Rung around, googled and there is some scary potential like alternator being engine out job etc. I tested battery on optimate 4 and says OK, but ???
Think I'll try a new battery and take from there. Any recommendations, book just says says agm 12v 12ah.
If charging system knackered it's a 2k job.
- Has thanked: 541 times
- Been thanked: 7594 times
Re: Bmw r1200gs battery??
I've just replaced my battery.
The one I bought from Tayna wasn't the correct one, it was maybe an inch short. Still works fine, just wedged a bit of foam the under it.
The one I bought was...
PTZ14S Powerline Motorcycle Battery 12V
It was £32 delivered.
- Has thanked: 7852 times
- Been thanked: 2555 times
I don't know a huge amount about the 1200 series. Could be a duff wire in a loom? Have you checked out the bmw specific forums? There's generally a lot of knowledge there that you wouldn't necessarily pick up from googling.Dodgy69 wrote: ↑Tue Aug 20, 2024 10:03 am On Sunday the might GS stopped. Dash went wierd, speedo stopped working. Pulled into lay-by and tried to re start but no. Mate got his trailer.
Just spoke to tech at work, he reckons it sound's more like a bad earth. Wouldn't start with jump leads. Dash doesn't work and headlight sometimes stays on when ignition off. My optimate 4 says battery good.
- Has thanked: 16152 times
- Been thanked: 10327 times
Stick a jump lead on the negative terminal to a good earth point on the frame. That'll tell you if its an earth issue.
Good earth points seem hard to find on first glance. Will give another go.
- Has thanked: 9901 times
- Been thanked: 10212 times
I'd try a new battery first before worrying about anything else. In my (limited) experience with boxer twins,they like a battery to be tip top condition and they used to be quite sore on batteries.
- Has thanked: 543 times
- Been thanked: 479 times
Don’t scrimp on batteries on big twins… need a lot of cold cranking amps to get them going! And a cheap battery will always be the first point of failure…
Genuine Yuasa and nothing less IMO… Think it’s a YTZ14S in that bike but double check first, I might be wrong…
Update...battery is knackered 7.6 v. Put jump leads from car and now reads 13.8v. Dash all normal. Push starter and click coming from starter relay, no power to starter motor. Thinking is, relay is knackered aswel. Tomorrow gonna bridge black and red at relay, bypass relay switch and see if starter motor turns engine and fires up.
Sometimes, just jumping it doesn't work if the battery is fubar. You need to give it a minute or two connected before trying and make sure the car is running!
- Has thanked: 604 times
- Been thanked: 2470 times
Chuck a battery at it, this is my Striple hooked up to a running car, you can hear it running in the background and see the voltage as measured at the bike battery, won't even try and kick the starter motor in, 1 new battery later, job jobbed.Dodgy69 wrote: ↑Tue Aug 20, 2024 8:04 pm Update...battery is knackered 7.6 v. Put jump leads from car and now reads 13.8v. Dash all normal. Push starter and click coming from starter relay, no power to starter motor. Thinking is, relay is knackered aswel. Tomorrow gonna bridge black and red at relay, bypass relay switch and see if starter motor turns engine and fires up.
- Has thanked: 10336 times
- Been thanked: 6915 times
No. No. No. Never with car engine running. Can blow the electrics on the bike.KungFooBob wrote: ↑Tue Aug 20, 2024 8:07 pm Sometimes, just jumping it doesn't work if the battery is fubar. You need to give it a minute or two connected before trying and make sure the car is running!
Why?Yorick wrote: ↑Tue Aug 20, 2024 8:10 pmNo. No. No. Never with car engine running. Can blow the electrics on the bike.KungFooBob wrote: ↑Tue Aug 20, 2024 8:07 pm Sometimes, just jumping it doesn't work if the battery is fubar. You need to give it a minute or two connected before trying and make sure the car is running!
Maybe if your car alternator is over charging and your bike has no fuses.
Dunno. But seen it mentioned a million times before. I just assumed it was dangerous.KungFooBob wrote: ↑Tue Aug 20, 2024 8:12 pmWhy?Yorick wrote: ↑Tue Aug 20, 2024 8:10 pmNo. No. No. Never with car engine running. Can blow the electrics on the bike.KungFooBob wrote: ↑Tue Aug 20, 2024 8:07 pm Sometimes, just jumping it doesn't work if the battery is fubar. You need to give it a minute or two connected before trying and make sure the car is running!
- Has thanked: 6413 times
- Been thanked: 4797 times
Everything I've seen about using jump leads car to car says with engine running. Can't see why a bike should be different.KungFooBob wrote: ↑Tue Aug 20, 2024 8:12 pmWhy?Yorick wrote: ↑Tue Aug 20, 2024 8:10 pmNo. No. No. Never with car engine running. Can blow the electrics on the bike.KungFooBob wrote: ↑Tue Aug 20, 2024 8:07 pm Sometimes, just jumping it doesn't work if the battery is fubar. You need to give it a minute or two connected before trying and make sure the car is running!
As mentioned above I reckon the battery is kaput.
I'm with Yorick here, never jump a bike from a running vehicle. A spike can kill your ecu.
Voltage...? Yes...
Current... Noooooooooo!
As others have already said... Should never jump start a bike off a running car battery or anything else with a much larger potential current spike. On your BMW GS the CANBUS system would probably save the ECU and just trip out, but you might not be so lucky. On most bikes a current spike could easily fry an ECU, or melt a regulator/rectifier or even burn a stator. Just not worth the risk IMO...
Well, you live and learn eh?. (Not that I've ever tried to jump start a bike with a car, but have done car to car many times). Puzzled as to why a car on tick over would have an output spike and why this isn't a problem for a modern car on the receiving end too. (Our 'laptop on wheels' car instructs you to have the 'donor' car running).
