No, me and my wife tried to explain it to our two (18 and 20), I think it offended their woke sensibilities.Ian wrote: ↑Thu Aug 08, 2024 8:26 pmBoth my kids know who Joey was, does that make me a bad parent?Le_Fromage_Grande wrote: ↑Thu Aug 08, 2024 5:14 pm Neither of them understand why "Joey" is an insulting term.
Odd Seldom used Words
- Been thanked: 4124 times
Re: Odd Seldom used Words
- Has thanked: 1346 times
- Been thanked: 1722 times
Close, I first heard in relation to processing radiographic film so pretty much the same thing.mangocrazy wrote: ↑Thu Aug 08, 2024 9:50 pmI first got to know about reciprocity in connection with the word 'failure'. It's a film photography thing. Anyone else encountered it in that connection?
Seem to remember "Reticulation" being a thing as well. That might have been from changes in temperature between the dev and stopper? Was a while ago so I've forgotten a lot of it now.
- Has thanked: 2550 times
- Been thanked: 6244 times
I know reciprocity from technical jargon. Its pretty common to use it when describing vibration, signals, AC power...all those interconnected fields with lots of sin waves, transfer functions and complex numbers.
"Reticulation" always makes me think of Giraffes...many of which are reticulated.
- Has thanked: 2402 times
- Been thanked: 3625 times
Reticulation typically happens when the film emulsion is moved from a warm medium to a cold one, and the emulsion shrinks rapidly, causing a blotched or mottled effect. This often happens in winter when the wash water is much colder than the fixer. Reciprocity failure is when the linkage between aperture setting and shutter speed breaks down as exposure times get longer. You need to give two/three/four times the length of exposure when shutter speeds go below a second or more.demographic wrote: ↑Thu Aug 08, 2024 10:18 pmClose, I first heard in relation to processing radiographic film so pretty much the same thing.mangocrazy wrote: ↑Thu Aug 08, 2024 9:50 pmI first got to know about reciprocity in connection with the word 'failure'. It's a film photography thing. Anyone else encountered it in that connection?
Not sure how digital handles long exposures... ?
- Has thanked: 484 times
- Been thanked: 1427 times
- Has thanked: 1507 times
- Been thanked: 1412 times
Also used to describe CCW permits valid in States other than the one that issued it.Mr. Dazzle wrote: ↑Thu Aug 08, 2024 10:53 pm I know reciprocity from technical jargon. Its pretty common to use it when describing vibration, signals, AC power...all those interconnected fields with lots of sin waves, transfer functions and complex numbers.
Ones with a reciprocal arrangement you mean?ZRX61 wrote: ↑Fri Aug 09, 2024 1:37 amAlso used to describe CCW permits valid in States other than the one that issued it.Mr. Dazzle wrote: ↑Thu Aug 08, 2024 10:53 pm I know reciprocity from technical jargon. Its pretty common to use it when describing vibration, signals, AC power...all those interconnected fields with lots of sin waves, transfer functions and complex numbers.
- Has thanked: 6376 times
- Been thanked: 4751 times
I like 'incandescent' when it's used to mean 'angry'.
Incandescent with rage.
Nicely poetic and slightly undermines the meaning by being so lovely
In a similar sort of vein I quite like effervescent and exuberant to describe behaviour.
- gremlin
- Has thanked: 808 times
- Been thanked: 4793 times
I like fire-related words, such as 'razed' to the ground, which always sounds oxymoronic. I also like 'conflagration'. Sounds more grandiose than a plain-ol' fire.
I'm a fan of quintessence/quintessential. (Which appears to be 'fifth essence'. Wonder why fifth? Earth, water, fire and air plus one? ).Mr. Dazzle wrote: ↑Fri Aug 09, 2024 8:17 am Incandescent with rage.
- Has thanked: 6187 times
- Been thanked: 5087 times
Interesting that in fire service lingo, a huge fire is 'well alight'.
It's the fifth indefinable element innit? Hence why we use the word Quintessential to mean that ineffable* essence you can't put your finger on, but which is really important.Count Steer wrote: ↑Fri Aug 09, 2024 9:31 amI'm a fan of quintessence/quintessential. (Which appears to be 'fifth essence'. Wonder why fifth? Earth, water, fire and air plus one? ).Mr. Dazzle wrote: ↑Fri Aug 09, 2024 8:17 am Incandescent with rage.
Conflagration is another word I hear alot. There are two types of combustion/ignition. Conflagration and detonation. The former is when heat transfers primarily through conduction and convection, spreading fire that way, the latter is when heating occurs because of the compression caused by a supersonic shock wave.
Detonation is enormously more efficient at heating things up and extracting energy, which is why detonation ignition engines are one of the holy grails of ICE.
It also tends to be somewhat more destructive . Indeed the thing which makes high explosives "high" is the fact they use Detonation ignition.
*there's another one!
I was going to post ineffable! (Mainly associated with a hymn with a lot of nice words in - I'd quite like a chariot of wrath ).
http://www.hymntime.com/tch/htm/o/w/t/k/owtking.htm
PS 5th indefinable element....umami.
PPS Panoply.
(Originally a full suit of hoplite - Greek foot soldier - armour)
PPS Panoply.
- gremlin
You forgot to add 'innit?' at the end.
- Has thanked: 10263 times
- Been thanked: 6885 times
Yanks use precipitation on TV weather forecasts.
What's wrong with good old fashioned rain?
- Has thanked: 599 times
- Been thanked: 2436 times
- Cousin Jack
- Been thanked: 2285 times
You don't get too many "shiboleth"s today.
(Apart from a certain group, you know who you are.)
The missus has contributed 'palimpsest' as a favourite. It's the traces of writing on a manuscript that have been erased so the paper can be reused but is used to suggest a ghost, shadow, echo or trace of something. She knows how to use 'paradigm' properly too. Smartypants.
