- Ditchfinder
- Has thanked: 574 times
- Been thanked: 617 times
I love broad beans, especially in a ham and broad bean risotto, but they are difficult to find fresh in this country (well up north anyway) yet we export or use as animal feed most of what we grow in the UK
https://www.theguardian.com/science/art ... -scientist
'07 Griso 1100 7 '94 Sprint 900
- Has thanked: 2318 times
- Been thanked: 3373 times
I really like broad beans as well, but the only way to get hold of them on a regular basis is in the frozen supermarket aisles. If I ever see them fresh I snap them up, but that doesn't happen often.
They're great in a green Thai curry.
- Has thanked: 2609 times
- Been thanked: 6012 times
I used to do PYO broad beans with my Mum when I was a kid. I'm gonna see if I can find somewhere to do it with Baby D, now I think on it
I suppose I could just grow them
Those pods look so comfortable inside.
- Been thanked: 2499 times
The water stop cock in my house. When the valve is open the lever is across the direction of flow and when closed it's in line with the direction of flow. Aha I thought, I'll take the handle off and rotate in 90 degrees on the shaft. Nope, it has a stadium shaped* driveshaft and socket not a square one.
*A similar shape to the pistons used in the Honda NR750 engine. They aren't oval, ovals are curved all round, stadiums have straight sides.
- Has thanked: 7726 times
- Been thanked: 2400 times
Weird. I wonder if the internal parts were assembled 90 degrees out somehow? (Or the wrong internals used).cheb wrote: ↑Tue Jul 30, 2024 7:25 am The water stop cock in my house. When the valve is open the lever is across the direction of flow and when closed it's in line with the direction of flow. Aha I thought, I'll take the handle off and rotate in 90 degrees on the shaft. Nope, it has a stadium shaped* driveshaft and socket not a square one.
Seems totally counter-intuitive to have the lever aligned that way.
I doubt that much thought went into the manufacturing specs. It's not a quarter turn tap, just the usual windy up and own one.
I dealt with the wrongly aligned quarter turn taps soon after arrival.
- gremlin
- Has thanked: 776 times
- Been thanked: 4513 times
Stadia, surely.
And with any mains tap, as long as it turns when needed, then it's a good 'un.
Hypercorrection apparently: https://en.wikipedia.org/wiki/Hypercorrection
Not as bad as shouting 'Bravo' instead of 'Brava' at the opera though.
- Has thanked: 6262 times
- Been thanked: 4613 times
An industrial ceramics academic at Leeds Uni insisted on pronouncing the word as keramics because 'the Greek root is keramos' (potter's earth). He wasn't the only one - it was a bit of an academic snobbery thing for a while.
A bit like surgeons calling themselves Mr or Mrs as historically they weren't physicians.
But then most doctors aren't Doctors.
- Has thanked: 852 times
- Been thanked: 1225 times
I've just had the 6th (I think) visit from the Stoves techs to fix my cooker. Their fault finding methods sounded normal to me so not a big rant about them but the problem turned out to be* loose power cables inside the cooker, not impressed with what is meant to be a premium brand.
* Needs more testing.
The local boulangerie has no bread! None at all! Not one baguette!
Revolutions have started for less in France...
- Has thanked: 15601 times
- Been thanked: 9847 times
B&Ms not having any Tingly Teds in!
I had to make do with the last croissant.
- Has thanked: 5943 times
- Been thanked: 4926 times
Cementite, also known as iron carbide, is a hard, brittle, and metallic compound of iron and carbon with the chemical formula Fe3C.Count Steer wrote: ↑Tue Jul 30, 2024 9:23 am An industrial ceramics academic at Leeds Uni insisted on pronouncing the word as keramics because 'the Greek root is keramos' (potter's earth). He wasn't the only one - it was a bit of an academic snobbery thing for a while.
Semen tite, as our lecturer called it.
- Has thanked: 16251 times
- Been thanked: 3744 times
Queueing at a fuel station! I mean, not the queueing per se, although it was bastard hot, but how people behave!!
When I go, if I have to use cash, I'll stop away from the pump is there is a queue, pay the cash, get the little ticket thing (from a sort of cash machine thingy) and then join the queue
Today there were queues at each side of all the pumps (and I'm in inappropriate kit on a hot Honda and it's nearly midday )
So I did that, went and got my top up ticket and sat in the queue. Luckily not in my queue, but a woman had waited for three other cars to fill up before she got to the pumps, THEN she got out and went to get the cash ticket thingy FFS, that's just rude!! If she'd been in front of my queue I think that by then I'd have squelched over and told her very politely that she's a dick and should consider getting the ticket first!! THEN when she'd got the ticket she then got back in the car to find some plastic gloves to put on before she did the fuelling
It's almost as bad as people who get back in the car and then sit whilst they note the mileage etc, reposition the seat and anything else they can think of before moving off! Have seen bikers fanny arse around getting sorted too. Just pull away to the area ahead where there's loads of space and no queue behind you so then do all the faffing!! I put the fuel in and refitted the tank bag, pulled off, then stopped in the space and sorted gloves etc etc!!
Some people are just rude!!
Something I want/need from IKEA not being available from my nearest one, and not being available for delivery either.
I'll either be driving to bloody Nottingham to pick it up, or finding somebody to blackmail who can pick it up from somewhere that has it in stock for me
The tit who bounces off the rev limiter when he reaches the speed camera up the road. Not because of the noise at all but because that's the usual noise when someone pulls out on a bike and knocks them off at the junction opposite. Sends a shudder down my spine every time.
- Has thanked: 465 times
- Been thanked: 1372 times
During the week i had a guy at the Tesco pump in one of them two seater Smart car things drive to the second pump from the entrance. As i was turning up he was reversing back to the first pump as it was out of petrol, Diesel only. He stopped between the pumps and got out to fill up. OK fuck you mate. I drove round him and left my van at an angle across the front of his car and started to full up a large almost empty tank. The fucker had the cheek to give me the dirty looks when he walked past to pay. Unfortunately no one came up behind to prevent him from reversing back to pass me but FFS. Another six foot back he would have still been close the the filler cap and i could have parked flush to the pump.Noggin wrote: ↑Tue Jul 30, 2024 1:43 pm Queueing at a fuel station! I mean, not the queueing per se, although it was bastard hot, but how people behave!!
