Broken down
Has thanked: 1507 times
Been thanked: 1412 times
Re: Broken down
Slenver wrote: Sat Jul 20, 2024 5:55 pm Seized rose joint on the rear brake lever
How old is the bike?
Slenver
Has thanked: 650 times
Been thanked: 865 times
Re: Broken down
Post by Slenver »
Taipan wrote: Sat Jul 20, 2024 7:42 pm Image
Actually that one's quite good :)
Slenver
Re: Broken down
Post by Slenver »
ZRX61 wrote: Sat Jul 20, 2024 8:08 pm
2017
Slenver
Re: Broken down
Post by Slenver »
Have to say though, I really liked the 990 Duke!
Faarking expensive though.
Has thanked: 2550 times
Been thanked: 6244 times
Re: Broken down
Slenver wrote: Sat Jul 20, 2024 8:10 pm
2017
Well no wonder it broke down!
Re: Broken down
Slenver wrote: Sat Jul 20, 2024 8:10 pm 2017
I'd be investing in a can of AeroKroil... I work on 80yo stuff & the perfectly fine rose joints are original.
Slenver
Re: Broken down
Post by Slenver »
ZRX61 wrote: Sat Jul 20, 2024 8:25 pm
The guy did say it was quite common for them to seize.
Mind you, he also said they've been getting a lot of broken gearboxes recently too, so I'm happy with a seized rose joint tbh.
Nobby
Has thanked: 85 times
Been thanked: 477 times
Re: Broken down
Post by Nobby »
Skub wrote: Sat Jul 20, 2024 12:39 pm
Slenver wrote: Sat Jul 20, 2024 12:38 pm I mean... maybe like 2% better?
Can ye no crack a caliper nipple and back off the pads as a 'get home' effort?
I took the Pads out on my TRX when they decided to lock up. Managed to do this with my keys (pulling out the R clip )
Sensible riding home was no problem as the engine braking is the equivalent or better than the rear brakes. Though it's very tempting to touch the front lever.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Broken down
In August 1999 I went to a solar eclipse party/festival in Hungary on my VFR750 and on the way back the Reg/Rec decided to throw a hissy fit and start charging at 17v, boiling the battery dry. After realising what the problem was, and refilling the battery with distilled water, the rear brake torque arm then decided to fracture, leaving me not only with no rear brake, but fearful of the consequences if I even so much as touched the rear brake.
I think I jury-rigged some kind of arrangement with cable ties such that it was almost impossible to use the rear brake and rode from Austria back to the UK trying to force my right foot not to go anywhere near the rear brake pedal.
katana
Has thanked: 68 times
Been thanked: 36 times
Re: Broken down
Post by katana »
So you bought your bike a rose....
katana
Re: Broken down
Post by katana »
mangocrazy wrote: Sat Jul 20, 2024 10:29 pm In August 1999 I went to a solar eclipse party/festival in Hungary on my VFR750 and on the way back the Reg/Rec decided to throw a hissy fit and start charging at 17v, boiling the battery dry. After realising what the problem was, and refilling the battery with distilled water, the rear brake torque arm then decided to fracture, leaving me not only with no rear brake, but fearful of the consequences if I even so much as touched the rear brake.
So much for a reliable honda
Re: Broken down
katana wrote: Sat Jul 20, 2024 10:45 pm
In fairness, dodgy Reg/Recs are a well known failure point on VFRs of that era. I've had 3 go on me. And the rear brake torque arm failure was due to a non-standard rear wheel fitment that went wrong. Blame attaches to the fabricator there, not the bike.
