Sora - AI Video Generatiion
- ChrisW
- Has thanked: 2913 times
- Been thanked: 2053 times
- Been thanked: 7530 times
Re: Sora - AI Video Generatiion
Finally, mine and Natalie Portman's sex tape might become a reality!
- Has thanked: 15957 times
- Been thanked: 10248 times
Bloodyfuckinghell!ChrisW wrote: ↑Fri Feb 16, 2024 7:45 pm This is seriously impressive:
https://openai.com/sora
Stock footage & mis-information ahoy!
- Has thanked: 734 times
- Been thanked: 716 times
I caught a small part of a discussion on AI. Can't remember the precise terms used but essentially it was "AI is no longer a subject of human technology. Humans are the subject"
Struck me as a bit weird.
AI is working us out.
- Has thanked: 836 times
- Been thanked: 1239 times
Or that's just someone's fantasy they want to convince others is real.
- Has thanked: 6376 times
- Been thanked: 4753 times
It's a slightly sensationalist way of putting it but it's right in the sense that AI uses our outputs as inputs. There will come a time when the inputs include significant material generated by other AIs* which is a bit
None of it is original 'thought' though, but then again, how much of what hoomans generate on-line is?
* At the moment I think some people claim AI can distinguish between AI generated output (in academic scenarios) and human productions. Dunno how long that will be true, even if it is now.
When I was trying ChatGPT to see if it was any use I noticed it had a limited set of answers to a specialist subject and would roll out those same answers in different ways, it also made the same mistakes repeatedly. I suspect anyone marking digitised exams can use machine learning to spot those patterns pretty easily, they can probably even identify which text books were used.Count Steer wrote: ↑Thu Feb 29, 2024 7:30 amIt's a slightly sensationalist way of putting it but it's right in the sense that AI uses our outputs as inputs. There will come a time when the inputs include significant material generated by other AIs* which is a bit
