Beggars belief
wull
Has thanked: 880 times
Been thanked: 1544 times
Beggars belief
Post by wull »
This was too good not to share.
We secured a new contract with a local company that maintains grass bankings, grass areas around pathways etc. They were with another place but weren’t happy with them.
So they bring me in this John Deere lawnmower that has transmission problems, the wheels keep locking up. They had put it in to the other place and were told it was needing a new gearbox and had quoted £600, so I said I’d have a look see what’s what.
Here’s the mower, this was after I had fixed it, washed etc.
And here’s the slip from the other place, and next to it is all that was wrong with it 🤦‍♂️ the nut had got jammed in between the gear on the rear wheel and the gear on the output shaft from the gearbox. They clearly hadn’t bothered their arse to look and just quoted for a gearbox. Madness. Someone must have left it in there when they’ve had the wheel off, put the wheel on replaced the nut and at some point it’s finally got jammed causing the problem.
Been thanked: 7530 times
Re: Beggars belief
So you're going to tell them it was the gearbox and only charge £500.
Has thanked: 7817 times
Been thanked: 2528 times
Re: Beggars belief
KungFooBob wrote: Thu Jun 20, 2024 3:32 pm So you're going to tell them it was the gearbox and only charge £500.
It's the way of the true capitalist.
Has thanked: 9828 times
Been thanked: 10145 times
Re: Beggars belief
Wull,the too honest spanner jockey takes a pay cut this month. :(
Has thanked: 6376 times
Been thanked: 4753 times
Re: Beggars belief
Skub wrote: Thu Jun 20, 2024 4:20 pm Wull,the too honest spanner jockey takes a pay cut this month. :(
Wull, the honest engineer gets a bonus for securing a new maintenance contract with a valuable customer. :thumbup:
Has thanked: 2551 times
Been thanked: 6245 times
Re: Beggars belief
wull gets no credit whatsoever and just another job to do most likely :D
Sadlonelygit
Has thanked: 85 times
Been thanked: 688 times
Re: Beggars belief
Post by Sadlonelygit »
This air filter has allegedly only been fitted for 30 miles by a KTM dealer.
They also missed 2 leaking fork seals and front pads at 1.4mm and a broken engine mount!
Re: Beggars belief
What vehicle was it fitted in before those 30 miles?
Has thanked: 15957 times
Been thanked: 10248 times
Re: Beggars belief
Mr. Dazzle wrote: Thu Jun 20, 2024 4:33 pm wull gets no credit whatsoever and just another job to do most likely :D
Ahh, defeat snatched from the jaws of victory!
katana
Has thanked: 68 times
Been thanked: 36 times
Re: Beggars belief
Post by katana »
Sadlonelygit wrote: Thu Jun 20, 2024 5:14 pm This air filter has allegedly only been fitted for 30 miles by a KTM dealer.
Are you a girl? As girls get charged more as they know nothing. Such as charging for a cabin filter and fitting of 1/2 hour labour when there isn't one. Also spark plugs that are 100km spark plugs that were changed 10k ago.
Sadlonelygit
Re: Beggars belief
Mr. Dazzle wrote: Thu Jun 20, 2024 5:29 pm What vehicle was it fitted in before those 30 miles?
125 duke
Sadlonelygit
Re: Beggars belief
katana wrote: Thu Jun 20, 2024 5:39 pm
Not the last time I looked!
Not my bike, but that of an innocent wide eyed teenager
Spark plug had a 1.2mm gap!!
katana
Re: Beggars belief
Post by katana »
Did the plug look worn? I'd be sceptical if it had worn to that diameter.
Sadlonelygit
Re: Beggars belief
katana wrote: Fri Jun 21, 2024 4:18 pm Did the plug look worn? I'd be sceptical if it had worn to that diameter.
std gap is 0.9, doubt it was measured before being fitted!
