NBT: I’ve just bought my forever bike, part 2!
- Has thanked: 5969 times
- Been thanked: 3573 times
Re: NBT: I’ve just bought my forever bike, part 2!
That's why mine is still in the garage. Cold I can do, washing bikes...nah hate it.
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Do the plastic footrest areas cope ok with the muck? Wondered if they get scuffed up with the slimy grit!
- Has thanked: 20883 times
- Been thanked: 13701 times
The muddy sign of it, yes. It was a dirty but I decided to come home on roads that are between fields which had flooded and put silt over the roads!
*****SOLD*****
Nah, not really.
A colleague said today that he couldn't believe I still had it! That makes 2 of us!
TBH I don't even look at other bikes anymore. This really is a keeper.
Super comfortable and economical and I just enjoy pootling about on it and even in this weather i often take the longer route home.
Nah, not really.
- Has thanked: 6125 times
- Been thanked: 15507 times
Needs some nice scenic pics of a CLEAN shiny bike in the sunshine.
I've not actually got round to cleaning it yetweeksy wrote: Thu Apr 25, 2024 7:37 am Needs some nice scenic pics of a CLEAN shiny bike in the sunshine.
I'm others are as good, but this was a game changer for cleaning spoked wheels!
Parked out the front all shiny and in full view.
Now you've done it.
Now you've done it.
- gremlin
- Has thanked: 1102 times
- Been thanked: 5882 times
You're right. The neighbours will never speak to him again now they know he rides a scoot.Skub wrote: Thu Apr 25, 2024 1:35 pm Parked out the front all shiny and in full view.
Now you've done it.![]()
- Has thanked: 2858 times
- Been thanked: 3517 times
Its always out the front. I don't bother hiding it.
Not sure its a downside as such, but the bike is too bloody quiet! The Akra has a db killer in, and they are only a tad louder without the db killer so it should be bang on, but you have to drill a hole in the c/fibre end cap to get access to the retaining bolt?!
I cant see exactly where to drill it and don't want to f-up the end cap. Ho-hum. Apart from that I'm still really pleased with it and cant see it going anywhere for weeks or even months yet!
You can just move the end cap and re-rivet it, but i'd like the easier option of access to the retaining bolt. Found a few vids now, so it maybe a goer after all...
It's a common mod. Akra even sell the rubber bungs to cap the 10mm holes. I didn't do mine because I didn't want the bike any louder. Once the cat was gone,it's plenty loud enough.Taipan wrote: Fri Jun 07, 2024 5:56 pm Not sure its a downside as such, but the bike is too bloody quiet! The Akra has a db killer in, and they are only a tad louder without the db killer so it should be bang on, but you have to drill a hole in the c/fibre end cap to get access to the retaining bolt?!I cant see exactly where to drill it and don't want to f-up the end cap. Ho-hum. Apart from that I'm still really pleased with it and cant see it going anywhere for weeks or even months yet!
I don't want to decat it, but with the cat and a baffled silence it is whisper quiet. Keeping the cat and removing the db killer would hopefully be a nice balance, if its too loud, back in the db killer goes.Skub wrote: Fri Jun 07, 2024 8:06 pmIt's a common mod. Akra even sell the rubber bungs to cap the 10mm holes. I didn't do mine because I didn't want the bike any louder. Once the cat was gone,it's plenty loud enough.Taipan wrote: Fri Jun 07, 2024 5:56 pm Not sure its a downside as such, but the bike is too bloody quiet! The Akra has a db killer in, and they are only a tad louder without the db killer so it should be bang on, but you have to drill a hole in the c/fibre end cap to get access to the retaining bolt?!I cant see exactly where to drill it and don't want to f-up the end cap. Ho-hum. Apart from that I'm still really pleased with it and cant see it going anywhere for weeks or even months yet!
I'd bet even if you took the whole can off with the cat in place,it would still be quiet. Taking out the baffles will probably make little difference if you keep the cat. Try it first and see.Taipan wrote: Fri Jun 07, 2024 8:26 pm I don't want to decat it, but with the cat and a baffled silence it is whisper quiet. Keeping the cat and removing the db killer would hopefully be a nice balance, if its too loud, back in the db killer goes.![]()
You may have just saved me a job!Skub wrote: Fri Jun 07, 2024 8:45 pmI'd bet even if you took the whole can off with the cat in place,it would still be quiet. Taking out the baffles will probably make little difference if you keep the cat. Try it first and see.Taipan wrote: Fri Jun 07, 2024 8:26 pm I don't want to decat it, but with the cat and a baffled silence it is whisper quiet. Keeping the cat and removing the db killer would hopefully be a nice balance, if its too loud, back in the db killer goes.![]()
- Has thanked: 8046 times
- Been thanked: 5697 times
People used to ditch the can and just fit a short tailpipe on BMW GS's and, iirc, they still met the decibel rules and regs, just sounded a bit more fruity. Fuelling didn't need changing either. I think the cat is quite a labyrinth internally.Skub wrote: Fri Jun 07, 2024 8:45 pmI'd bet even if you took the whole can off with the cat in place,it would still be quiet. Taking out the baffles will probably make little difference if you keep the cat. Try it first and see.Taipan wrote: Fri Jun 07, 2024 8:26 pm I don't want to decat it, but with the cat and a baffled silence it is whisper quiet. Keeping the cat and removing the db killer would hopefully be a nice balance, if its too loud, back in the db killer goes.![]()
