What's it called and where can I get it done?
Sadlonelygit
Has thanked: 85 times
Been thanked: 689 times
Post by Sadlonelygit »
I have an idea for her anniversary present this year.
I want to preserve! a plastic clothes peg in resin.
The peg is special ok!
I've seen flower preservation, but pretty sure a peg doesn't need that level of preparation.
Is it something you could do yourself with a suitable mould, or anyone on here do this kind of thing?
Tia
Has thanked: 2551 times
Been thanked: 6247 times
Re: What's it called and where can I get it done?
Casting resin you mean?
These guys sell it and all the gubbins you'd need. You can probably also find it cheaper elsewhere, but I can highly recommend Easy Composites as 'legit'. I used their stuff at work, even when I worked for a composites company :D
I bet there are loads of instructional vids on YouTube. There's also some info on EC's website.
https://www.easycomposites.co.uk/casting-resins
Been thanked: 7530 times
How do you stop the peg from sinking to the bottom before it sets?
Slenver
Has thanked: 650 times
Been thanked: 865 times
Post by Slenver »
KungFooBob wrote: Wed May 22, 2024 11:09 am How do you stop the peg from sinking to the bottom before it sets?
Do it in two layers?
Edit: I know fuck all about this btw, but I make a mean trifle.
Has thanked: 809 times
Been thanked: 4802 times
I know all about this, as a resin piece featured in the Gremlinette's art GCSE work (A*, thanks for asking ;) ).
Create the form, mix the resin, pour and push the object in. As said, you can it in layers if the object is heavy to stop it sinking to the bottom.
In fact, I have a resin kit sat in a drawer that never got used, just waiting for a project...
Slenver wrote: Wed May 22, 2024 11:19 am
Do it in two layer?
Or do it in zero g.
I suggest this all the time at work as the solution to all kinds of problems, no matter how effective it would be no-one ever goes for it :(
Slenver
Post by Slenver »
Mr. Dazzle wrote: Wed May 22, 2024 11:26 am
Do it in two layer?
Or do it in zero g.
I mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.
How long does it take to set?
Slenver wrote: Wed May 22, 2024 11:31 am
Do it in two layer?
Or do it in zero g.
Long enough that it would be a peg, bone fragments and part of your spleen in the resin. ;)
Slenver
Post by Slenver »
gremlin wrote: Wed May 22, 2024 11:35 am
Or do it in zero g.
That sounds sub-optimal
Sadlonelygit
Do it in two layer?
Or do it in zero g.
Will that work in a R22?
Has thanked: 599 times
Been thanked: 2443 times
Expect bubbles, unless you've got a vacuum chamber or pressure pot
Slenver
Post by Slenver »
Sadlonelygit wrote: Wed May 22, 2024 11:48 am
Or do it in zero g.
Don't see why not
Sadlonelygit
Slenver wrote: Wed May 22, 2024 11:52 am
Don't see why not
Rather than perform a parabolic arc, ime 🚁 just.............drop
Potter wrote: Wed May 22, 2024 12:00 pm It’s interesting.
In another life I had a job where we’d get to occasionally play about with pressures in a sealed system to control the temperature when stuff turns to a gas and I found it really interesting, e.g. you can hold water in a vessel well over 100c without it boiling using system pressure.
"Well over" is underselling it :D You can get water way higher than 100°C with the right pressure, and indeed even 'normal' power stations run up well into the hundreds and hundreds of celsius.
Once you get really hot though 'water' and 'steam' start to become the same thing. Power stations run over on the right of this graph where green and yellow overlap, once you're above the critical point water and steam are essentially the same thing - or they're some other thing with a different name, depends what you want to call it.
Whatever you call it, you certainly don't want a leak :o
Has thanked: 6378 times
Been thanked: 4755 times
I've seen IG stuff where they make 'river tables' by pouring stuff into gaps between slices of tree. Single or multiplepour. They don't seem to have bubble problems. 2 part epoxy, low exotherm. This is listed as 'deep pour epoxy river table resin' but the company does lots of stuff, some sorts are on Amazon.
https://www.clearcastresins.co.uk/deep- ... n-29-p.asp
Count Steer wrote: Wed May 22, 2024 12:09 pm I've seen IG stuff where they make 'river tables' by pouring stuff into gaps between slices of tree. Single or multiplepour. They don't seem to have bubble problems. 2 part epoxy, low exotherm. This is listed as 'deep pour epoxy river table resin' but the company does lots of stuff, some sorts are on Amazon.
Re: bubbles - we always used to Degas resin (when making certain kinds of carbon fibre) in a vacuum chamber. Basically mix it up, stick it in the vacuum chamber, draw a vacuum and watch the resin bubble up like just poured champagne. Wait for the bubbles to disappear and then you're good.
Surface bubbles on wet resin can be dealt with using a blow torch.
Has thanked: 2942 times
Been thanked: 1883 times
Potter wrote: Wed May 22, 2024 12:25 pm
Mr. Dazzle wrote: Wed May 22, 2024 12:07 pm
Well yeah, I didn't want to be too boring :lol:
I have a few questions that I used to throw out in interviews to immediately see where someone was at, one of them was "How can I make a cup of water boil at 70c?"
It's a very easy question, but if you don't know then you don't know.
Back onto the subject, there are some brilliant videos on Youtube of people making tables and things using resin and bits of all sorts of things, I particularly like the old wood and resin tables, you can use coloured resin and make some really nice stuff. It's on my list of things to do once I've retired and got time to bugger about.
My old physics teacher used to do an experiment where he could get water boiling at about 38C, pointing out that that this was why tea at altitude tastes rubbish.
I once spent about 40 mins cooking rice in Breckenridge CO (altitude 9500ft) and wondering why it was still pretty al dente :D
Watch some long form youtube videos on it, they can have the devil of a time with bubbles, for a casting of a thing in resin I'm guessing the aim is for crystal clear with polished sides.
For tables https://www.youtube.com/@BlacktailStudio and https://www.youtube.com/@John_Malecki
For resin in moulds https://www.youtube.com/@nickzammeti and https://www.youtube.com/@BensWorx
And still nobody has asked the relevance of the peg....
