Pitch can vary. For example M10 x 1.25 pitch or M10 x 1.5 pitch.Yorick wrote: ↑Fri May 10, 2024 3:47 pm I thought metric was metric. But no.
Had to buy a front brake lever guard for the Suzuki . So took the 12mm bolt out of the bar end and wandered into town to buy a longer one.
Bugger, it's a finer thread than standard 8mm
No shops had them.
So had to buy another guard with adapter kit.
50 of your feelthy Engleesh Quids
Mechanical experts - Help needed.
- Has thanked: 9828 times
- Been thanked: 10145 times
Re: Mechanical experts - Help needed.
- Has thanked: 10265 times
- Been thanked: 6886 times
Aye. That wobbled my memory a bit.Skub wrote: ↑Fri May 10, 2024 4:15 pmPitch can vary. For example M10 x 1.25 pitch or M10 x 1.5 pitch.Yorick wrote: ↑Fri May 10, 2024 3:47 pm I thought metric was metric. But no.
No shops had them.
And I'm sick that the bloody guards weren't even checked
- Has thanked: 2551 times
- Been thanked: 6247 times
Somewhere 'round here I've a little doodad I kept from Mercedes GP just to prove how daft F1 is sometimes. It's got MJ5* threads on the inside, MJ7 on the outside and a 95° countersink Nobody uses 7mm threads...except Mercedes F1.Skub wrote: ↑Fri May 10, 2024 4:15 pmPitch can vary. For example M10 x 1.25 pitch or M10 x 1.5 pitch.Yorick wrote: ↑Fri May 10, 2024 3:47 pm I thought metric was metric. But no.
No shops had them.
*WTF is an MJ thread? Exactly
- Has thanked: 253 times
- Been thanked: 143 times
It puts extra requirement on the root like a whitworth. So presumably better for strength and fatigue and so on
Some Borg Warner turbochargers use M7x1.0 bolts. They need an 11mm spanner to undo themMr. Dazzle wrote: ↑Fri May 10, 2024 4:30 pm
- Has thanked: 565 times
- Been thanked: 754 times
A year or so ago I had a similar problem. I don't remember whether I needed a nut to fit a screw or a screw to fit a nut, but I took the offending item to B&Q and the nice man there was very helpful. That's where I'd start.Cousin Jack wrote: ↑Thu May 09, 2024 2:04 pm...
Back in the day I would go down to my local ironmonger and tell him what I want and he would either produce one from the dusty recesses of he shop, or at least tell me what to search for elsewhere. Unfortunately ironmongers are no more.
Any ideas?
- Has thanked: 218 times
- Been thanked: 689 times
[/quote]
Most of the staff at B&Q won't know a screw from a nut....
- Cousin Jack
- Has thanked: 2552 times
- Been thanked: 2286 times
[/quote]
And much of the stuff is now sealed in little plastic pouches, so no more try before you buy.
- Cousin Jack
