very slow draining kitchen sink
- formula400
- Has thanked: 434 times
- Been thanked: 817 times
Right guys I need some help, kitchen sink has become very slow to empty, I've taken the U pipe off underneath the sink and there was some gunk in there but nothing blocking it. I've put 2 bottles of Mr Muscle Max Gel Unblocker down there, 1 yesterday and 1 this afternoon, left them both 2 hours, still the same, any ideas what to try next???
thanks
thanks
CBR650r
- Has thanked: 699 times
- Been thanked: 698 times
Re: very slow draining kitchen sink
Get some caustic soda... mix it up strong...
Let that soak for an hour or so, then use a plunger on it make sure you seal the overflow when you plunger it.
- Has thanked: 604 times
- Been thanked: 3875 times
Wot Wratty said, and you'll need to be quite vigorous with the plunger, pretend you're a Porn Star
- formula400
this stuff??? https://www.diy.com/departments/caustic ... 329_BQ.prd
CBR650r
That's the kiddy...
It will heat up like fuck when you mix it up. Always add the soda to water, not water to soda... use a wooden spoon to mix it... its very exothermic when you mix it...
That one might even be pre-mixed. I have some granules you have to mix.
- formula400
It wont get melt your pipes up hot...it will get hot though. If its pre-mixed it wont get hot at all.
- Has thanked: 5324 times
- Been thanked: 4551 times
The compressed air cans can work when a plunger doesn't. As advised, block the overall. And whatever you block it with, hold that firmly in place
Well you're no fun, water to soda is a lot more fun, if not particularly safe, you'll be telling him next not to put it anywhere near any aluminium.Wreckless Rat wrote: ↑Mon Nov 16, 2020 3:39 pm Always add the soda to water, not water to soda... use a wooden spoon to mix it... its very exothermic when you mix it...
He's the only one on here who can give you really good dessert recipes.... look after him is my motto.Julian_Boolean wrote: ↑Mon Nov 16, 2020 4:06 pmWell you're no fun, water to soda is a lot more fun, if not particularly safe, you'll be telling him next not to put it anywhere near any aluminium.Wreckless Rat wrote: ↑Mon Nov 16, 2020 3:39 pm Always add the soda to water, not water to soda... use a wooden spoon to mix it... its very exothermic when you mix it...
- Has thanked: 748 times
- Been thanked: 1093 times
Have you checked the other end of the pipe?
More than once I've put my efforts into the wrong section of drain only to find an outside drain or sewer is blocked.
- Has thanked: 298 times
- Been thanked: 975 times
Did the words "Denis" and "Nilsen" not spring to anyone else's mind when the OP's post?
Just me?
Just me?
- Has thanked: 983 times
- Been thanked: 328 times
I'd be cautious what you're putting down it as we ended up with a massive leak everywhere just in time for xmas - we had to do the washing up in the bathroom until we could get it fixed .
I just shout at people not to put tea leaves down the drain hole to no avail....
- Has thanked: 531 times
- Been thanked: 635 times
I will refer you to the answer my colleague, Patrick*, gave when asked if he had any idea how to open a locked case where the keys were missing: Semtex.
* Definitely Patrick, he objected to being called Paddy.
Si hoc legere scis, nimium eruditionis habes.
- Has thanked: 14068 times
- Been thanked: 9020 times
What he said! ^^^
On mine I used to push the hose up the pipe with the tap on full. Often the fat that clogs up drains is cooling and setting further down than the ubend.
- Yambo
- Has thanked: 577 times
- Been thanked: 1525 times
- Has thanked: 5 times
- Been thanked: 207 times
- Has thanked: 319 times
- Been thanked: 298 times
Get some rods, disconnect the pipe under the tap, push rods through so you at least know there's somewhere for large amounts of water to go having loosened it up, then use the hose, preferably with a thin gun attachment to start with. You don't want the water from the hose coming back up the pipe accompanied by a few years of gunk if there's not enough pressure to dislodge/create a hole at the blockage.
- Mr Moofo
- Has thanked: 1586 times
- Been thanked: 1281 times
And don’t put your hand into the caustic soda solution. Don’t ask me how I know.....
