Shadow foam toolbox/case
Been thanked: 15511 times
Re: Shadow foam toolbox/case
Version 2
ImageIMG_20240417_205412 by Steve Weeks, on Flickr
ImageIMG_20240417_205418 by Steve Weeks, on Flickr
I then look at it and think "hmmm the Allen sockets should be with the torque wrench. " so may need another change.
Needs some of this
We'll the foam sheets fit PERFECTLY in terms of depth, i've trimmed to size and got them in the box and they look ace. Still working on the layout as i pick and choose the tools that are more often used over the ones that fit best. No point having a tool i need ASAP if it's buried on the 2nd layer.
Has thanked: 10971 times
Been thanked: 4004 times
weeksy wrote: Fri Apr 19, 2024 8:54 am We'll the foam sheets fit PERFECTLY in terms of depth, i've trimmed to size and got them in the box and they look ace. Still working on the layout as i pick and choose the tools that are more often used over the ones that fit best. No point having a tool i need ASAP if it's buried on the 2nd layer.
I meant to take some photos of my tool drawers to "inspire" you, I was even in the workshop last night with the opportunity.
But I didn't know if you'd find it relevant or not.
weeksy wrote: Fri Apr 19, 2024 8:01 am Needs some of this
Might be worth keeping that little lot together in it's pouch and storing the pouch itself within a corner of the foam? (would it go in the case "on end" ?)
Rockburner wrote: Fri Apr 19, 2024 9:16 am
As always you can never have too much information :)
In this instance it's not how i'd lay it out in the garage for example, when in there i've got all the spanners in one drawer, all the allens in the next etc etc.. However for the MTB it's more a case of the 4/5/6/8 being in one place, the pressure gauge being in another, the hole punch in same place as that, the shock pump being in a certain place. It's more about things being exactly where they're needed and when, rather than just looking pretty. Obviously a lot of drawers are designed to look correct, but you end up in 3 places to get a couple of tools.
I've kinda got things how i want in my head but then change things a little bit each time. I sort of sit there and think "yup that's it..." but then i think "oh, do i really use those pliers often ? "
Rockburner wrote: Fri Apr 19, 2024 9:17 am
Yeah i wouldn't remove that. I've got a kit from @crust which was a present which stays in it's case, although that gets used less because of that :D
There's also one of these
I'd like that in the box but would be daft to remove from it's current tray as it fits perfectly.
weeksy wrote: Fri Apr 19, 2024 9:21 am
I'll pop over and take some pics today, found a couple of "before" photos but things definitely changed in the process!
Here's the album on Flickr : https://flic.kr/s/aHBqjBn1v7
I used a steel rule as the outline for the "finger-holes" to keep them consistent.
ImageIMG_20240421_111522 by Steve Weeks, on Flickr
ImageIMG_20240421_111509 by Steve Weeks, on Flickr
Getting there
I'd suggest a thin sheet of something to go between, just so any tools that happen to come a bit loose in transit don't rub on each other.
Yup, got that already when closed.
I was debating a sheet of 2mm MDF and some form of brackets, but the foam that came out of the lid does the job fine
Start of the 3rd layer
ImageIMG_20240421_121417 by Steve Weeks, on Flickr
Rockburner wrote: Sun Apr 21, 2024 11:25 am I'd suggest a thin sheet of something to go between, just so any tools that happen to come a bit loose in transit don't rub on each other.
Obviously.
https://www.easycomposites.co.uk/high-s ... ibre-sheet
Mr. Dazzle wrote: Sun Apr 21, 2024 7:50 pm
Obviously.
Needs to be embossed with the team logo.
Rockburner wrote: Mon Apr 22, 2024 8:32 am
Obviously.
True true.... That'd be kinda cool :)
Sunny
Has thanked: 3554 times
Been thanked: 1677 times
Post by Sunny »
I need to sort my tool chest out like this to stop the other inhabitant constantly losing my tools :evil:
What did you use to cut the foam? I feel like a Stanley knife would not be precise enough?
Just a little craft knife.
https://www.ebay.co.uk/itm/175454304560 ... R56PgM_gYw
Like this
Sunny wrote: Mon Apr 22, 2024 8:58 am I need to sort my tool chest out like this to stop the other inhabitant constantly losing my tools :evil:
If you buy the "kit" from ShadowFoam themselves, they supply a scalpel which is ideal (iirc).
https://shadowfoam.com/products/shadow-foam-packs
(or did I buy a special offer pack..?? I can't remember)
Sunny
Post by Sunny »
Cheers both!
