Gear change problems
Has thanked: 10272 times
Been thanked: 6889 times
Oooh. Don't come in here much..
Anyway, the gear change thingy stopped working on my last ride.
The push thingies both work OK, just the cable has become detached from the mechanism.
I'm sure I can fix it, just need to know what's wrong.
Can't see any way of securing the cable or getting it back into the little black thing in my hand which goes into a hole in the mechanism.
Has a bit dropped off?
Help
Ditchfinder
Has thanked: 622 times
Been thanked: 692 times
Re: Gear change problems
Post by Ditchfinder »
Comes in ere asking for help with his dusty bike bits - Good God man have you no Humanity - we haven't see the sun here since last June and have started growing gills !!!!
See the hole by your index finger that where the cable goes through - if you do that and trace a straight line you should see a threaded hole with a bolt and a .5cm square cable clamp. If you cant's see a 4mm head allen bolt (short) and cable clamp then you will have lost them or the bit with the threaded hole may have snapped off.
Probably should look like this: Image assuming it's 9 speed or maybe early 10 speed.
Clamp and bolt are available as spares though.
Ditchfinder
Maybe it is this mech: Image and where the clamp and bolt go is behind your middle finger in top photo
Looks like I've lost something and cable is frayed and won't go into the hole.
I'll nip it up to local shop. I don't know what I need, so will be simpler to give it to him
Cheers :)
Ditchfinder
Be about 10 euro for a clamp and bolt - get him to replace the cable at the same time - it looks fubarred. 10 mins of a job.
Has thanked: 2945 times
Been thanked: 1883 times
No mud on that bike @weeksy, BAN HIM! 😂😂
MingtheMerciless wrote: Mon Apr 15, 2024 5:59 pm No mud on that bike @weeksy, BAN HIM! 😂😂
Don't have mud here :D
Has thanked: 5452 times
Been thanked: 13097 times
You appear to have rust
weeksy wrote: Mon Apr 15, 2024 6:18 pm You appear to have rust
My brother owned it in UK for many years.
mboy
Has thanked: 527 times
Been thanked: 456 times
Post by mboy »
Full new inner and outer cable, it's not worth replacing one or the other on its own... Should be about £10-15 plus any labour charge in a bike shop and be running good as new again. 👍🏻
mboy wrote: Wed Apr 17, 2024 12:26 am Full new inner and outer cable, it's not worth replacing one or the other on its own... Should be about £10-15 plus any labour charge in a bike shop and be running good as new again. 👍🏻
I dropped it off at the local bike shop.
Yorick wrote: Wed Apr 17, 2024 8:53 am
€12.50 :obscene-birdiedoublered:
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
I hate fecking derailleurs.
