A right now thread
Has thanked: 6376 times
Been thanked: 4753 times
Re: A right now thread
Mr. Dazzle wrote: Sun Apr 14, 2024 2:44 pm
Count Steer wrote: Sat Apr 13, 2024 3:21 pm
Noggin wrote: Sat Apr 13, 2024 2:40 pm
???? Do they need to be warm to work?? I see loads out on balconies here!!!
I think it's less of a problem for freezers but iirc if the exterior temperature is less than the device interior they can go into reverse or summat.
Kinda don't need the fridge in that situation anyway right, even if it were the case?
If it goes into reverse heat pump mode it may heat the inside? @Rockburner will probably remember what the issue was.
Has thanked: 2551 times
Been thanked: 6245 times
I wouldn't have thought so, but maybe...
The 'hot side' is always outside the box, I can't think of way for a fridge to run in reverse but I certainly haven't spent an enormous amount of time poking around domestic fridges :D
Way more fundamentally though, if the interior gets very cold then the thermostat just won't kick in anyway. The fridge won't try and run 'cause the inside is already cold. At which point it just becomes an overblown cupboard?
Mr. Dazzle wrote: Sun Apr 14, 2024 4:17 pm I wouldn't have thought so, but maybe...
There's a few explanations if you Google 'why don't fridges work in the cold' inc coolant operating temperature range, thermostat. One thing suggested that, because there's only one compressor on a fridge/freezer and the fridge thermostat thinks everything is cold enough...the freezer thaws out. :hmmm:
Has thanked: 7817 times
Been thanked: 2528 times
Count Steer wrote: Sun Apr 14, 2024 3:53 pm
The inside didn't get hot. It just didn't get cold enough because iirc a domestic fridge it's designed for an exterior temperature above about 7 degrees, (or something). Below that they just don't operate, and the internal temp rises to match the external.
Sunny
Has thanked: 959 times
Been thanked: 519 times
Post by Sunny »
Getting a ferry across the Thames.
(Stayed at a different Canary Wharf hotel than usual, which involves a complementary ferry 🤣)
Been thanked: 2286 times
Sitting in the dentist's waiting room. Only a check up, but always a tad unsettling.
Bloody cold here today, not the 23 C it was in Spain. :(
Has thanked: 6191 times
Been thanked: 5087 times
Puppy asleep, so sit quietly / coffee / book* ... and enjoy it while it lasts :)
* Jo Nesbo (Harry Hole) Killing Moon
Has thanked: 15957 times
Been thanked: 10248 times
Picking up after having two Bobcats* fighting in the house. Like a bastard wrecking crew when they are chasing each other around the place and fighting! :crazy: Good entertainment though! :D
*French Bulldogs
636mick
Has thanked: 1079 times
Been thanked: 720 times
Post by 636mick »
Washed the bike ready for MOT, so did the car too, just got to vac it. Off out for a ride after vac and cuppa.
Then some sleep ready for nights later.
Suns out, 9 degrees but it’ll do for now!!
Mick
Has thanked: 836 times
Been thanked: 1239 times
Rockburner wrote: Sun Apr 14, 2024 7:30 pm
The reason I read years ago was some fridge freezers only have one thermostat in the fridge which controls cooling for both, if the unit is used in freezing temps then the fridge thermostat never gets warm enough to switch on and the freezer ends up defrosting.
So fridge freezers with 2 thermostats would be ok.
Sunny
Post by Sunny »
Chilling with a pre-dinner glass of fizz on the rooftop terrace of the Malta Marriott on my last visit here for possibly ever. 😱
Unless I set up a near-shore office here for my new place 😆😇
Has thanked: 16210 times
Been thanked: 3925 times
Standing at a very cold bus station. Looks like the bus times have changed bus no one has amended any of the info! Here’s hoping the 19:15 one arrives cos I’ll be peeved if it doesn’t ☹️☹️
Sitting in a crap airport hotel . Take off for Malta at 0625 tomorrow morning.
Sunny wrote: Thu Apr 25, 2024 5:17 pm Chilling with a pre-dinner glass of fizz on the rooftop terrace of the Malta Marriott on my last visit here for possibly ever. 😱
We (me and Mrs CJ) arrive tomorrow, staying at the Phonecia. Wave as you go to the airport.
Sunny
Post by Sunny »
Cousin Jack wrote: Thu Apr 25, 2024 7:03 pm
Nice place 👍 Will do 😆 Have fun! 😎
Has thanked: 2942 times
Been thanked: 1883 times
Eating a late breakfast.
View from the balcony in Malta.
Sunny
Post by Sunny »
10 mins south, and eight hours earlier :mrgreen:
Sunny wrote: Fri Apr 26, 2024 3:41 pm 10 mins south, and eight hours earlier :mrgreen:
You had the better weather. Cloudy here this evening, and a bit chilly.
Sunny
Post by Sunny »
Cousin Jack wrote: Fri Apr 26, 2024 5:58 pm
It pissed it down on Wednesday afternoon/evening if that helps! Lovely yesterday and this morning though 😊
Here's hoping you get more of that 👍
