Thus also solving any power cut concerns. Any big hospital has a UPS system for such eventualities.
I actually helped make a bunch of the hardware for one of the London hopsital ones. They replaced loads of massive lead acid batteries with ultra high speed glass/carbon flywheels. We called them the Mach 3 flywheels, cause that's how fast the edges went. Well...they ran in a vacuum, but you see what I mean.
Batteries/flywheels can do uninterrupted power for sort of 15-20 mins while the diesel generators fire up.
- Has thanked: 7572 times
- Been thanked: 5904 times
Off on a temporary tangent. Did they have a heavy outer ring? Just thinking that a flywheel needs mass to be effective?Mr. Dazzle wrote: Sat Mar 16, 2024 12:24 pm Thus also solving any power cut concerns. Aultra high speed glass/carbon flywheels. We called them the Mach 3 flywheels,
It's needs kinetic energy in this context (energy storage)...traditional obtained by spinning a heavy thing slowly, but it's actually more effective to spin a light thing fast. V squared innit.
Just much more technically challenging!
- Has thanked: 20757 times
- Been thanked: 13585 times
Or stop wasting time with slow handovers. Open back doors, Reverse at speed. Hit brakes...MrLongbeard wrote: Sat Mar 16, 2024 12:00 pm Given the delays in handover times when dropping off at A&E the solution is simple, just jack the ambos in to a fast charger when they rock up at the hospital.
Regen braking - puts power in the batteryTaipan wrote: Sat Mar 16, 2024 12:47 pmHit brakes...MrLongbeard wrote: Sat Mar 16, 2024 12:00 pm Given the delays in handover times when dropping off at A&E the solution is simple, just jack the ambos in to a fast charger when they rock up at the hospital.
Win-Win!
I'm in the market right now and I would have an electric car......if I liked any of them. I've had a really good look and i just don't. I think maybe it needs another 4-5 yrs to get enough choice
So I think the next ICE car will be the last one of those we'll buy. Although I'm struggling to find man of those I like, it's wall to wall boring grey SUVs
Happened across an Aussie reel where they talk about real world ranges as found by What Car magazine. This is an issue that comes up often. Do car manufacturers lie as badly about ice ranges?
Another interesting point they make, is if the range is that much less than the manufacturers claims, then they are recharging more, which is another knock of the EVs green credentials.
As a household I'd guess at 90% of our trips being local and range wouldn't really be an issue for us and I would like a leccy bike and car, but I cant see that happening for some time yet and i get a sense of relief that I didnt buy the Tesla i was intending too. I just get the feeling the whole EV thing is hype, smoke and mirrors. But, as someone that developed LOA (late onset asthma) it would certainly suit me if every car in London was a EV as the immediate air would be lot cleaner, whatever the bigger picture is...
Of course they do, everyone knows they do and they expect it. It's just that it's quoted in terms of MPG, rather than range.
Is there a standard EV test, like the ICE rolling road 'urban cycle'?Mr. Dazzle wrote: Sun Mar 17, 2024 10:17 amOf course they do, everyone knows they do and they expect it. It's just that it's quoted in terms of MPG, rather than range.
Yeah there are WLTP tests for the official range/economy just like with ICE engines.
The real numbers typically aren't rolling roaded AFAIK. Lots of rolling road testing happens of course, but IIRC your official numbers have to come from a real "full test" car, I'm not sure.
https://evdb.nz/wltp
- Felix
- Has thanked: 707 times
- Been thanked: 2003 times
85mpg one say say i should get on a run with the wifes DS3. Sitting at 70 returned 59 tops. I am more than happy with that as the last car was 36 ish.Mr. Dazzle wrote: Sun Mar 17, 2024 10:17 amOf course they do, everyone knows they do and they expect it. It's just that it's quoted in terms of MPG, rather than range.
Up to 40% off according to that test. To my mind that's pretty scandalous!Mr. Dazzle wrote: Sun Mar 17, 2024 10:17 amOf course they do, everyone knows they do and they expect it. It's just that it's quoted in terms of MPG, rather than range.
It's because "range" is actually quite a complicated term.
When i filled my diesel car up last week the dash said I had ~550 miles in the tank. I drove 40 miles to work and it then said I had 750 miles. I "gained" 200 miles of range while also driving 40...how does that work?
Is that scandalous. If it had been the other way around, and the range had dropped from 700 to 500 (because I'd gone from motorway to urban, rather than vice versa) would I have grounds to complain?
Of course, its because the efficiency of the car changes enormously depending on the type of driving I'm doing. So it is with EVs, but to a smaller degree.
Trying to say a car has a "range of X" is almost a meaningless question. It depends massively on how you use it. But we're now in the place where people expect a single value from an EV manufacturer and equally want to say "aha! Gotcha!" when that enormously simplified value is wrong.
My car does a genuine 70mpg on the motorway. If the manufacture said it does that all the time you'd cry BS, and rightly so. Why do you expect different from another fuel/technology?
'Up to'? Hmm terrible. Scandalous even. Is that what you're saying? Agreed? OK, let's continueTaipan wrote: Sun Mar 17, 2024 10:41 amUp to 40% off according to that test. To my mind that's pretty scandalous!Mr. Dazzle wrote: Sun Mar 17, 2024 10:17 amOf course they do, everyone knows they do and they expect it. It's just that it's quoted in terms of MPG, rather than range.
One British company, Emissions Analytics, has tested over 800 vehicles over the last decade covering a wide range of makes, models and engine types. Its Equa Index also enables the company to forecast fuel economy for cars it hasn’t yet tested.
The company’s tests have found that the average car’s fuel economy is 25% lower than official NEDC numbers, with some vehicles as much as 40% below the laboratory figure.
Oh deary deary me ...
- Has thanked: 12533 times
- Been thanked: 8507 times
Just found this thread...electric? Yes please. Why? A mate travels the country most days, around 270 miles a day. ... and has a tesla p85d variant. It's quite old now and has done about 175000 miles.
His contention is that range anxiety is suffered by people who don't have electric cars. He will stop once a day for half an hour which gives him 80% charge.
More to the point it has 720bhp. It's fucking insane. We have an arrangement where if I'm anywhere near Huddersfield he drinks and I drive so I've played with this thing enough times to know that without any shadow of doubt I'd seriously enjoy having one.
It's not scandalous though, and nobody's to blame, especially not the manufacturers as it's nothing to do with them. The test is a standard European one that they are legally obliged to do. Sure, it's not very accurate in the real world, same as the equivalent ICE economy one often isn't.Taipan wrote: Sun Mar 17, 2024 10:41 am
It's an imperfect world
The question really is whether the real-world range is enough for what you/whoever need it for.
It's certainly a PR challenge for the manufacturers though.
EVs are just well...different...than ICE cars in a lot of ways. Much of "stuff everybody knows" is just different, not necessarily better or worse, just different.
Range is a really obvious one. Everyone knows that cars get better economy "on a run". Except they don't. Piston engines get better economy on a run, it's a characteristic of that engine type, not cars in general.
And so on.
And so on.
I'm just surprised that with todays somewhat stringent consumer laws that such inaccuracies are allowed. But with range being the biggest draw back for most people I guess that's a bonus for the manufacturers.
It's not strictly inaccurate though and it's certainly not new. ICE is exactly the same. For a manufacturer to claim a range an EV will have to have actually demonstrated it can do that in real life.
The figures come from a standardised WLTP test, just like MPG figures do with ICE cars. All manufacturers have to do it and they have no say in the test parameters*.
Like Slenver said, it's not really anything to do with the builders and it's been this way for decades.
*Beyond the fact the WLTP was originally created in part by manufacturer input
