- Has thanked: 2554 times
- Been thanked: 6262 times
Most leccy cars....virtually all in fact, can't think of an example where it's not the case...are fixies, there's no way to disconnect the motor from the wheels. There's no need! Motor will just freewheel if you push the car. A very few have a 2 speed gearbox, but there's no neutral.
If the electronic motor control systems broke its very very very unlikely they'd break in such a way as the drive the motor. More likely it'd just spazz out and refuse to go. It takes pretty fine control to actually make it drive.
- Has thanked: 201 times
- Been thanked: 217 times
The runaway Jag story is very fishy . I read in one account ( can't remember DT or BBC ) it was the second time it had happened , after Jaguar gave it the all clear following the first event .
Current electric cars just don't fit the bill for me either. Style matters, and range anxiety is a real concern.
- Has thanked: 15992 times
- Been thanked: 10261 times
I suspect like one someone murders an intruder, they get charged so their innocence can be proven?
- Has thanked: 86 times
- Been thanked: 693 times
Murder has to be premeditated, so unless you have machine gun nests set up with a killing zone in the kitchen/diner, more likely to be manslaughter, which in the course of defending you and yours, is hard to prove, unless you batter the fucker after they have ceased resisting or chase them down and inflict instant justice!
My bad, I should have said killed not murdered…Sadlonelygit wrote: ↑Thu Mar 14, 2024 7:07 pmMurder has to be premeditated, so unless you have machine gun nests set up with a killing zone in the kitchen/diner, more likely to be manslaughter, which in the course of defending you and yours, is hard to prove, unless you batter the fucker after they have ceased resisting or chase them down and inflict instant justice!
- Has thanked: 839 times
- Been thanked: 1242 times
I thought the difference was that murder is an intentional act be it premeditated or not, manslaughter is unintentional.Sadlonelygit wrote: ↑Thu Mar 14, 2024 7:07 pmMurder has to be premeditated, so unless you have machine gun nests set up with a killing zone in the kitchen/diner, more likely to be manslaughter, which in the course of defending you and yours, is hard to prove, unless you batter the fucker after they have ceased resisting or chase them down and inflict instant justice!
These definitions are probably flexible depending on the amount of social media outrage but neither is as bad as cutting down a Sycamore tree.
- Has thanked: 567 times
- Been thanked: 757 times
Yebutt. Sycamore trees don't just grow on...Mussels wrote: ↑Thu Mar 14, 2024 7:45 pm I thought the difference was that murder is an intentional act be it premeditated or not, manslaughter is unintentional.
Oh. As you were.
- Yambo
- Has thanked: 598 times
- Been thanked: 1647 times
Nobody has to prove their innocence, the state has to prove their guilt.
- Pirahna
- Has thanked: 1817 times
- Been thanked: 1167 times
I've had two friends killed and the killers then convicted of manslaughter. One of them I'll put a link below, the first was back in the 80's. A friend, Colin McGregor, had words with a couple of pikies in a pub in Wood Green, London. The pikies went back to their caravans and when Colin left the pub they were waiting outside with a baseball bat each and beat him to death. They didn't mean to kill him, only teach him a lesson, both got seven years.
Ray Eden: https://www.bbc.com/news/uk-england-sou ... e-14509571
4years and 9 months! Ffs I bet he was out after 3 years.Pirahna wrote: ↑Fri Mar 15, 2024 8:13 am I've had two friends killed and the killers then convicted of manslaughter. One of them I'll put a link below, the first was back in the 80's. A friend, Colin McGregor, had words with a couple of pikies in a pub in Wood Green, London. The pikies went back to their caravans and when Colin left the pub they were waiting outside with a baseball bat each and beat him to death. They didn't mean to kill him, only teach him a lesson, both got seven years.
NHS dropping leccy ambulances as they only get 70 miles to a 4 hour charge, compared to an ice 800 miles and refill in minutes.
- Has thanked: 6202 times
- Been thanked: 5090 times
One news story (DM & Telegraph seem to have similar, word for word) says:
Standard ambulances can cover up to 800 miles a day
Later in the article:
Standard ambulances cover 800 miles a day
That's a continuous 33mph for 24 hours, non-stop. Doesn't sound realistic, unless at the very top end of 'up to' and solely involving very long, high-speed, transfers.
On calls I attend, crews typically spend an hour at the scene. Even on a recent incident where they needed to get going to A&E very quickly, it was probably at least 20 minutes from arriving to leaving.
Probably makes more sense as a sentence if you replace "can" with "could". As in, they could do that, but they don't. I'd guess in Central London for example they do like 2.8 miles a day or whatever.
I would imagine the problem with an ambulance is the uncertainty of when you need it. Plus the absolutely piss poor planning of the NHS
Wouldn't be my first choice of EV application.
There's a surprising amount of planning required for ambulance despatch. It's not just what's nearest, also needs to account for imminent breaks, etc.Mr. Dazzle wrote: ↑Fri Mar 15, 2024 12:11 pm.
And that's assuming they're not stacked up at A&E.
Longest drive I've heard of is 45 minutes / 25+ miles, cross-country.
Have you got a link? All I can find are several sites saying the NHS are expanding their trials to more areas.
- Has thanked: 7822 times
- Been thanked: 2532 times
I suspect the issue is charging times, rather than range.Horse wrote: ↑Fri Mar 15, 2024 12:20 pmThere's a surprising amount of planning required for ambulance despatch. It's not just what's nearest, also needs to account for imminent breaks, etc.Mr. Dazzle wrote: ↑Fri Mar 15, 2024 12:11 pm.
- Has thanked: 10280 times
- Been thanked: 6892 times
Couldn't the ambulance plug in at the house at each call?
Then have bit more time to care for each patient.
Wins all round
Wins all round
Only if he doesn't take power from the kettle
If you were gonna trial it, surely you'd do it in London or Birmingham etc. Somewhere which had lots and lots of small stop-start journeys which are ideal for an EV, not out in the sticks. Double whammy cause the fuel savings somewhere like that would be way more significant.Horse wrote: ↑Fri Mar 15, 2024 12:20 pmThere's a surprising amount of planning required for ambulance despatch. It's not just what's nearest, also needs to account for imminent breaks, etc.Mr. Dazzle wrote: ↑Fri Mar 15, 2024 12:11 pm.
