Taking the front wheel off an old Giant
- Has thanked: 665 times
- Been thanked: 1163 times
Hello!
Finally got round to tidying the garage. Don’t want to get rid of the Giant I’ve had for years. Went to try and get the front wheel off to put a new inner tube on- but unless I’m being super thick- I can’t see how to release the wheel.
The usual quick release thingy on other bikes just isn’t there. Any help appreciated
- Has thanked: 5449 times
- Been thanked: 13085 times
Re: Taking the front wheel off an old Giant
It's broken/fallen off.
I have no clue how you'd do it without. You or I won't be shocked by this, but i've NEVER seen that before
Oh well lol
I wonder if it’s possible to use the quick release from another bike and have at it?
I'd take it to Rotec Cycles in Reading and get him to sort, it MAY be possible to retro-fit another from another fork to get it out.
It's basically wound out in the usual lefty loosey manner, but it's then got a tightner as you flip the lever over, which may stop it from just being able to be opened. If you want to go at it, basically stick something in the cut-out, and wind it out... but i'm not making any promises.
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
Is it a skewer or a thru axle? - I can't see on my screen clearly
- Mr Moofo
From the picture , I couldn't make it out. The hex head has rounded off ?
If so there should be a hex head on the other side that you can use.
However as it looks as though it has been left a long time, I would spray a lot of plus-gas or GT-85 around it first. If it wasn't Docca we were talking about, I might suggest a little bit of gentle heat.
no.
https://www.ebay.co.uk/itm/314012935686 ... UISrsL7CYw
But as to what's missing i can tell... but what's left and what you can do with it, i can't tell from the pic.
I'd say a tyre lever and anti-clockwise would get it... but without trying, i can't say.
- Ditchfinder
- Has thanked: 620 times
- Been thanked: 692 times
From what I can tell the lever is the bit that's missing. Looking at Weeksy's pic there appears to be an indent in the black collar. I would be using a suitable pice of wood/metal as a lever to try and wind it out using that indent for leverage.
Better pics would help though - especially end on
- Mr Moofo
Or a mole wrenchDitchfinder wrote: ↑Wed Mar 06, 2024 2:52 pm From what I can tell the lever is the bit that's missing. Looking at Weeksy's pic there appears to be an indent in the black collar. I would be using a suitable pice of wood/metal as a lever to try and wind it out using that indent for leverage.
Fuck sake lads, I have posted for ages and I’m still getting peltersMr Moofo wrote: ↑Wed Mar 06, 2024 1:13 pmFrom the picture , I couldn't make it out. The hex head has rounded off ?
- MingtheMerciless
- Has thanked: 2940 times
- Been thanked: 1882 times
It’s gotta be time for a new bicycle!
Being the thing over.Docca wrote: ↑Wed Mar 06, 2024 6:55 pmFuck sake lads, I have posted for ages and I’m still getting peltersMr Moofo wrote: ↑Wed Mar 06, 2024 1:13 pmFrom the picture , I couldn't make it out. The hex head has rounded off ?
You’re too far away now mate.
I’ll take better pictures tomorrow
- Mr Moofo
@Docca
@weeksy
I have just been out to the man-shed to look at a pair of Rockshocks of that era, with the very same axle.
There should be a QR type level - that locks it in to a hard plastic / alloy cap.
It the lever is missing the indent, where the lever sits is a locked position, will be able to be pushed around by a tyre lever (if greased / loose-ish). As suggested by Weeksy.
If not I would suggest drifting it around ( anticlockwise), a screwdriver would work - but may be fairly destructive. A solid wood batten or a tough tyre lever hit with a soft hammer would be kinder. If the threads have been greased, once it starts moving, it should be fairly easy to turn.
@weeksy
