Suzuki powered Honda
Well I like it
Buckaroo
Has thanked: 735 times
Been thanked: 718 times
Re: Suzuki powered Honda
Post by Buckaroo »
But what is it?
Honduki?
Suzda?
Been thanked: 2618 times
So do I like it. Do you have any more info on it?
Not really, the picture comes from Facebook Butchered Classics page, I don't know if it's CB1100R chassis, or CB750/900 with 1100R bodywork, engine is most probably 1200 Bandit
Been thanked: 7535 times
I still think Suzuki missed a trick by not officially importing the GSX1200SS, or by offering a modern equivalent to compete with the Z900RS.
If Suzuki made a GSXS 1000 styled like a GS1000 I'd buy one.
Has thanked: 2915 times
Been thanked: 2058 times
Suzuki and Honda don't really go in for the retro / Xth anniversary stuff in the way that Yamaha & Kawasaki do. Shame in a way.
Honda are missing out not officially importing this...
https://www.honda.co.jp/CB1300/
Especially now they do a version in the silver and blue Freddie Spencer AMA colours.
westers151
Has thanked: 459 times
Been thanked: 235 times
Post by westers151 »
Le_Fromage_Grande wrote: Sat Feb 24, 2024 6:30 pm FB_IMG_1708798744017.jpg
Why do that?
Badly fitting seat unit to fuel tank (crap shut lines), and bad seat. The same could have been done with the original engine and would look so much better (bodywork fitting).
If you're going to do this sort of thing, make sure the fit and finish look factory, otherwise it looks half finished/wank.
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
From what I remember of the 1200 Bandit the engine was like no other. It would breeze up to 90 mph in top very quickly but if you wanted to get into the power band you then had to change down at least two gears. If you find Honda's engines a bit characterless there might be enough reason to put an old Suzuki engine to good use.
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
roadster wrote: Sun Feb 25, 2024 9:09 am From what I remember of the 1200 Bandit the engine was like no other. It would breeze up to 90 mph in top very quickly but if you wanted to get into the power band you then had to change down at least two gears. If you find Honda's engines a bit characterless there might be enough reason to put an old Suzuki engine to good use.
Nope, the B12 didn't have a power band, its all over by 8.5k. You can put 1052 GSXR cams in them, but the ECU won't let it rev high enough to notice the difference. I have a B12 engine in my GSXR11 and its 114bhp at the wheel but it's making 100bhp at 6k.
People like putting 1127 gsxr engines into things because the cam make an easy 135bhp but they're near impossible to get now.
I've got an 1127 engine :)
Has thanked: 6196 times
Been thanked: 5088 times
roadster wrote: Sun Feb 25, 2024 9:09 am If you find Honda's engines a bit characterless
Well, they did invent the 'twist two handfuls, then wait' acceleration technique.
The reason for putting the Bandit engine in is usually because the Honda engine has shat itself and is too expensive to rebuild.
Sadlonelygit
Has thanked: 86 times
Been thanked: 691 times
Post by Sadlonelygit »
It's not another Solly special is it?
He has a habit of dropping big Suzuki motors into different chassis's
