Orange headlight cover: Legality and efficacy
I personally feel more noticed in amongst a sea of cars when I have an orange headlight, especially in murky weather or in the rain. Would the wisdom of the forum agree?
Also, is it legal in the UK? It’s an extremely common addition in South Africa where the law is ambiguous enough to get away with it.
Am I setting myself up for a fine here?
- IMG_0771 Large.jpeg (901 KiB) Viewed 559 times
- Mr Moofo
- Has thanked: 1787 times
- Been thanked: 1405 times
Re: Orange headlight cover: Legality and efficacy
Hmm, I think it would be an MOT fail. You might get away with yellow
- dern
- Has thanked: 1003 times
- Been thanked: 1722 times
Only yellow and white are legal in the uk.
Maybe it's the photo but that's closer to a tail light colour than I'd like and would be asking for trouble in terms of a pull and the risk of a head on collision.
- Has thanked: 626 times
- Been thanked: 4063 times
- Has thanked: 9674 times
- Been thanked: 9698 times
'Feel more noticed',is a bit vague.
- Has thanked: 7723 times
- Been thanked: 2399 times
It's about all it's good for really.
- Has thanked: 1053 times
- Been thanked: 354 times
I’ve got an orange/yellow one - I think the convention is if it can be removed without tools it’s ok …don’t quote me
- Has thanked: 5940 times
- Been thanked: 4925 times
My CB1000R has the indicators on all the time as DRLs, it confuses a lot of other road users, I wish I could turn them off.
- Has thanked: 532 times
- Been thanked: 7215 times
Indicators that flash off instead of on?Le_Fromage_Grande wrote: ↑Wed Feb 21, 2024 8:50 pm My CB1000R has the indicators on all the time as DRLs, it confuses a lot of other road users, I wish I could turn them off.
Septic and JDM bikes had those. Back in the day the fix was to swap some wires. I imagine with modern can-bus systems it's a bit more complicated than that.
- Has thanked: 2632 times
- Been thanked: 1498 times
I've got yellow ones on my XJ6 and Hornet and never had an issue. I use them less 'to be seen by drivers' than to help trainees see where I am in their mirrors, particularly when I'm mixed in with other traffic behind them.
I had an illegal purple one on my old FZ for a while...
Yes, but the rear indicators flash onKungFooBob wrote: ↑Wed Feb 21, 2024 8:53 pmIndicators that flash off instead of on?Le_Fromage_Grande wrote: ↑Wed Feb 21, 2024 8:50 pm My CB1000R has the indicators on all the time as DRLs, it confuses a lot of other road users, I wish I could turn them off.
I had a 2022 Grom and it was quite easy to take out the extra feed wire at the indicator connection inside the headlamp. After working out which wire is which a very small blade can be used from the open side to press down the locking tab of the metal contact and the pin will pull out from the plug and be isolated. Has to be done for both connectors of course.Le_Fromage_Grande wrote: ↑Wed Feb 21, 2024 8:50 pm My CB1000R has the indicators on all the time as DRLs, it confuses a lot of other road users, I wish I could turn them off.
I used that feed for separate daytime running lights mounted above the headlamp. When I sold the grom it was easy enough to put the contact pin back into the plug.
- Has thanked: 2609 times
- Been thanked: 6011 times
Swap the rear and fronts roundLe_Fromage_Grande wrote: ↑Thu Feb 22, 2024 12:24 pmYes, but the rear indicators flash onKungFooBob wrote: ↑Wed Feb 21, 2024 8:53 pmIndicators that flash off instead of on?Le_Fromage_Grande wrote: ↑Wed Feb 21, 2024 8:50 pm My CB1000R has the indicators on all the time as DRLs, it confuses a lot of other road users, I wish I could turn them off.
- Has thanked: 1 time
Why not just buy an odd colour LED? Orangey yellow is going to be 3000k approx
