Has thanked: 1445 times
Been thanked: 1329 times
Looks familiar...
Has thanked: 3130 times
Been thanked: 1624 times
Skub wrote: Wed Jan 31, 2024 8:36 pm
That's a bit like cleaning the house before the cleaner arrives. :lol:
I know it sounds daft,but the way I see it,I'm hoping it's just going to be a 'routine' service as opposed to fault finding & service.
If I take the bike for a couple of runs beforehand I'll be happy that all appears to be good with the bike.
Bustaspoke wrote: Wed Jan 31, 2024 8:33 pm I did but as the tax runs out tonight & I've lots of other stuff going on I decided to SORN it for a couple of months & nip out on the Triumph if we get the occasional good day,also the Triumph's 12K service is booked in mid Feb,so I want to get it back on the road & make sure it's running without any faults before it's service.
12k miles ought not to be anything other than oil & filter.
ZRX61 wrote: Thu Feb 01, 2024 4:43 am
You're in for a shock if you ever own a Triumph.Valve clearances,suspension linkages greased lots of other stuff.It's expensive .
https://www.youlesmotorcycles.com/motor ... iumph.html
On Triumph forum's people are paying more than that.Have a Google
Has thanked: 2318 times
Been thanked: 3372 times
ZRX61 wrote: Thu Feb 01, 2024 4:43 am 12k miles ought not to be anything other than oil & filter.
Shirley you cannot be serious... Engine oil & filter would need changing at a minimum at half that distance, and preferably sooner. 12k on most bikes is a major service, valve clearances, brake/clutch fluid change etc. etc.
Has thanked: 9673 times
Been thanked: 9697 times
mangocrazy wrote: Thu Feb 01, 2024 10:28 am
My 10R had nothing but oil and filter,a bit of grease and fluids for 30k miles. When the valve clearances were checked for the first time at 34k they were still in spec. I'd expect that from a modern Japanese bike.
Skub wrote: Thu Feb 01, 2024 10:46 am
I'd say that's pretty trusting of you to do 34k miles without even checking valve clearances. I wouldn't run a bike, even a modern Jap one, for 34k without at least checking valve clearances at 12k intervals. I might leave it a bit longer if I was racking up big mileages on a regular basis, but I haven't done that for well over 20 years.
But props to the big K - they do make very strong motors.
mangocrazy wrote: Thu Feb 01, 2024 11:01 am
Over 20k on the Zed now and all it's had is oil & filter and tyres. I'll probably have to change the front pads sometime soon. :lol:
mangocrazy wrote: Thu Feb 01, 2024 10:28 am Shirley you cannot be serious... Engine oil & filter would need changing at a minimum at half that distance, and preferably sooner. 12k on most bikes is a major service, valve clearances, brake/clutch fluid change etc. etc.
I didn't say it would be the first oil & filter change. I'm only familiar with Kaw needs.. which on my 123,232 mile ZRX11
has been bugger all.
mangocrazy wrote: Thu Feb 01, 2024 11:01 am I'd say that's pretty trusting of you to do 34k miles without even checking valve clearances. I wouldn't run a bike, even a modern Jap one, for 34k without at least checking valve clearances at 12k intervals. I might leave it a bit longer if I was racking up big mileages on a regular basis, but I haven't done that for well over 20 years.
Kaw's stop needing shims changing after about 50-60k miles. My ZRX11 hasn't needed any changing for over a decade (50+k miles).
I woke the Triumph up from it's Winter hibernation & went for a spin
Had a chat with one of my mate's who amongst other bike's runs a KTM 690,he told me his mate is buying a Voge 300 & they're doing some Green laning.On my way home I thought 'the evenings are getting lighter,then I realised the clock was still set to BST :roll:
Has thanked: 4241 times
Been thanked: 2755 times
Weather was actually pretty decent today, fairly bright and 13c. Shorts weather.
Supermofo wrote: Fri Feb 02, 2024 4:13 pm Weather was actually pretty decent today, fairly bright and 13c. Shorts weather.
Outside of sport,there is no valid reason why a fully grown man should wear shorts.
Fact.
Has thanked: 10108 times
Been thanked: 6649 times
Skub wrote: Fri Feb 02, 2024 4:36 pm
Fact.
I've got about 15 pairs of shorts. Only 1 pair of jeans.
Shorts every day of the year here.
Has thanked: 6261 times
Been thanked: 4611 times
Fact.
:thumbup:
Has thanked: 216 times
Been thanked: 665 times
Yorick wrote: Fri Feb 02, 2024 4:42 pm
Fact.
For once, I agree with Yozzer....I hate long trousers, even in Wales up a mountain I wore shorts all year, still do here in Worle.
Fact.
I tend to wear shorts Feb to Nov, hate long trousers. Maybe I should've been a postie
More muriels.
Sadlonelygit
Has thanked: 67 times
Been thanked: 556 times
Post by Sadlonelygit »
Nipped out for a quick coffee at the oily rag.
I was wondering why the average age of everyone there was 50+, then caught a glimpse of myself in the window!
Skub wrote: Sat Feb 03, 2024 1:28 pm More muriels.
Double yellows again, you little rebel. :D
Count Steer wrote: Sat Feb 03, 2024 2:19 pm
Paddy taking his driving test..
Examiner asks "What does a yellow line mean?"
Paddy says " No parking at all"
Examiner asks same about double yellows
Paddy says "No parking at all, at all"
:obscene-birdiedoublered:
