PSA stupid cheap mtb
Has thanked: 15960 times
Been thanked: 10248 times
Re: PSA stupid cheap mtb
weeksy wrote: Wed Jan 17, 2024 10:17 am
Skub wrote: Wed Jan 17, 2024 10:13 am Twelve hundred quid is a cheap bicycle now? :shock: :lol:
Just to scare you... this is what the boy races
https://www.trekbikes.com/gb/en_GB/bike ... Code=white
Having watched some of the vids of bicycle lunacy, especially some of the Red Bull stuff, I can see why these types of bicycles cost so much. They need to be built well to survive some of the punishment they receive! :crazy:
Has thanked: 2943 times
Been thanked: 1883 times
Strong, light, cheap, you can only pick 2.
Slenver
Has thanked: 650 times
Been thanked: 865 times
Post by Slenver »
Slenver wrote: Sat Jan 06, 2024 11:50 am I got one too. Couldn't resist.
Arrived yesterday.
Anyone want to buy a Vitus Nucleus? :)
MyLittleStudPony
Has thanked: 617 times
Been thanked: 407 times
Post by MyLittleStudPony »
Mine arrived too. I got it out of the box today. I can't see a front axle / quick release mechanism. Am I being daft or do I need to contact the supplier to send one?
Has thanked: 1829 times
Been thanked: 1469 times
MyLittleStudPony wrote: Sat Jan 20, 2024 12:45 pm Mine arrived too. I got it out of the box today. I can't see a front axle / quick release mechanism. Am I being daft or do I need to contact the supplier to send one?
I would have thought front axle was bolt through - it's not bolted across the bottom of the forks?
If not contact supplier
MyLittleStudPony
Mr Moofo wrote: Sat Jan 20, 2024 1:00 pm
I think it's just an Allen bolt. :oops:
Buckaroo
Has thanked: 735 times
Been thanked: 718 times
Post by Buckaroo »
MyLittleStudPony wrote: Sat Jan 20, 2024 1:34 pm
Thru axle :obscene-drinkingcheers:
MyLittleStudPony
Buckaroo wrote: Sat Jan 20, 2024 5:53 pm
It seems to be that and it does work. I have to say I preferred the old quick release for taking the front wheel off. But this isn't that much worse.
MyLittleStudPony
I'm chuffed to bits with the bike by the way. Nice one Weeksy.
Buckaroo
Post by Buckaroo »
MyLittleStudPony wrote: Sat Jan 20, 2024 6:04 pm
Make sure that you thoroughly grease the threaded section and the axle.
I've seen and have had to remove many seized thru axles. Same for caliper retaining pins of the screw in type. Lube the little sucker otherwise it's drilling out time.
