Who are our favourite/prefered supplier of bearings
katana
Has thanked: 68 times
Been thanked: 36 times
Post by katana »
Need some wheel bearings, so who are our favourite/prefered suppliers that are good not having fakes.
Which brand are decent and how to spot fakes of SKF/timkin/Kyoto thanks
Been thanked: 7526 times
Re: Who are our favourite/prefered supplier of bearings
I use a local bearing place, but online I don't think you can go too far wrong with Wemoto.
katana
Post by katana »
KungFooBob wrote: Thu Jan 18, 2024 7:32 pm I use a local bearing place, but online I don't think you can go too far wrong with Wemoto.
Look at the wemoto website but there is no mention of the brand that is supplied, apart from slingyglide bearings.
Has thanked: 599 times
Been thanked: 2428 times
https://www.bearingboys.co.uk/Bearings-1005-c
That's who I've used in the past, although admittedly not for a few years
wull
Has thanked: 880 times
Been thanked: 1544 times
Post by wull »
I use these guys for the machines I work on, half the price of the John Deere dealers and the likes, they do motorcycle bearings as well, in the past I used wemoto a fair bit.
https://www.wmtbearings.co.uk/Motorcycl ... utomotive/
kendo57
Has thanked: 253 times
Been thanked: 589 times
Post by kendo57 »
On the internet i also use Bearingboys and Simply bearings. I also look for old stock bearings off E Bay
which are branded quality but cheaper.
Has thanked: 9819 times
Been thanked: 10144 times
I've used a local N.I. place.
https://www.rotarybearings.co.uk
katana
Post by katana »
There are no local bearing places near me any more.
Don't think the company that had the vd discount exist anymore.
Has thanked: 2550 times
Been thanked: 6244 times
Bearing Boys, Bearing Traders and Simply Bearings.
Used 'em all at work and I've always received 'real' bearings so far as I can work out. I'm not entirely sure how you'd verify they're not fakes! Faking these things is as big a business as faking Rolexes :lol:
"Real" applications for me all come straight from SKF or whatever.
Has thanked: 6375 times
Been thanked: 4750 times
This thread got me nostalgic. I worked one Easter holiday delivering bearings around Yorkshire for Bearing Services Ltd in Bradford (first driving I'd done since passing my test was a driving job :D ). So I looked to see if they were still going. Sadly not but they lasted quite a long time and had a decent network across the north of England and supplied run-of-the-mill and big, exotic industrial stuff. I imagine you'll still find outfits like that in industrial areas.
Not much use to the OP though. :(
katana
Post by katana »
Well after obsessing far too much, remember the VD code from BSL Brammer, that became brammer, then Brammer Buck and Hickman and now Rubix.
That was a waste of time and why I obsesing to try and remember and could not go to sleep till I knew.
Has thanked: 2402 times
Been thanked: 3625 times
Koyo Bearings Europe are based in Dodworth, Barnsley. Dunno if they do direct sales, but they should be able to provide you with details of trusted suppliers. 01226 209000
katana
Post by katana »
Count Steer wrote: Fri Jan 19, 2024 9:18 am This thread got me nostalgic. I worked one Easter holiday delivering bearings around Yorkshire for Bearing Services Ltd in Bradford (first driving I'd done since passing my test was a driving job :D ). So I looked to see if they were still going. Sadly not but they lasted quite a long time and had a decent network across the north of England and supplied run-of-the-mill and big, exotic industrial stuff. I imagine you'll still find outfits like that in industrial areas.
Nostalgia, it is not what it used to be.
katana
Post by katana »
Mr. Dazzle wrote: Fri Jan 19, 2024 8:54 am Bearing Boys, Bearing Traders and Simply Bearings.
They fake NGK spark plugs?
Believe it is more down to rebranding of cheap inferior bearings.
Counterfeit parts are a real thing and a real issue! Massive problems in aerospace.
katana
Post by katana »
Mr. Dazzle wrote: Fri Jan 19, 2024 1:29 pm Counterfeit parts are a real thing and a real issue! Massive problems in aerospace.
That is a concern, especially with wheel bearings on a motorbike.
SKF even have an app to help identify real and fake bearings.
In the end,the bke owners went on ebay to buy bearing :roll: skf and fag bearings from DSF bearings. Lets see what arrives.
katana
Post by katana »
Bearings ordered on Friday and arrived here wednesday(today)
katana
Post by katana »
SKF and Schafeur have both confirmed that the items are genuine FAG and SKF bearings. Even though the SF bearings came in sealed plastic bags with bearing number and made in Italy.
Now do I add a little more grease or not.
Has thanked: 5450 times
Been thanked: 13085 times
katana wrote: Mon Jan 29, 2024 11:36 pm SKF and Schafeur have both confirmed that the items are genuine FAG and SKF bearings. Even though the SF bearings came in sealed plastic bags with bearing number and made in Italy.
Considering they seem to last 10 years on motorbikes, i wouldn't bother.
SKF add the right amount and the right kind of grease in the factory. You shouldn't need more.
